Joined: 03 Feb 2009 Posts: 42 Location: Yorkshire, United Kingdom Thanked: 0 times
Posted: Mon Nov 02, 2009 8:51 am Post Subject:
Driving rain. Leaking patio doors
Had to get the towels & bucket out again yesterday.
Whenever there's any driving rain/wind, it finds it's way between the lintel stone & the top of the patio door frame.
No doubt others will get this during such weather.
Can anyone suggest a good sealant to cure this ?
Joined: 21 Aug 2008 Posts: 352 Location: Manchester, United Kingdom Thanked: 2 times
Posted: Wed Nov 04, 2009 7:28 pm Post Subject:
some kind of drip to shed the water falling down the wall, before it has a chance to get to the gap, will be a great help.
otherwise mastic, silicone etc; should all do the job. all-weather sealants that stick to wet surfaces could be useful to you, but they are very sticky and unpleasant to deal with.
Posted: Thu Nov 05, 2009 10:15 am Post Subject:
to give strength to a sealant against thermal and other movements it needs a certain amount of depth, usually the width of the joint is about right.
this product is like putting clingfilm over the cracks.
are you sure that the water is inflitrating between the lintel and frame?
i had a similar problem but upon closer investigation (during and after rain) the water was suspected to be coming down inside the wall from gaps around the windows above. after resealing these the leak stopped.
flat roofs and edges of roofs in general would also be worth investigating, water will also travel inside a wall horizontally as well on it's way down.
Posted: Thu Nov 05, 2009 2:34 pm Post Subject:
Thanks for the ongoing advice guys. I'll get a pic of the area.
There is a strip of silicone along the outside seam of the Lintel/door frame & on closer inspection, it seems to be coming away in certain areas which look to be the points of water ingress.
The spray can be applied quite thickly. If ingress continues, I'll look further.
Posted: Thu Nov 05, 2009 2:40 pm Post Subject:
if it worked, professionals would use it.
you need to remove old silicone fully, reseal, and preferably fit a drip so that water is not running across the top and sides of your door and frame where it will find a way in somewhere eventually.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
