DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
double glazing
Post new topic   Reply to topic    DIYnot.com Forum Index > DIY Disasters
  View previous topic :: View next topic
Author Message
dogdog
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 05, 2009 10:15 pm    Post Subject:
double glazing
Reply with quote Thanks
how do i get the external glazing beads the rectangular ones out of a double glazed frame to replace the unit
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WHJOHNSON
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 06, 2009 8:45 pm    Post Subject:
The removable glazing beads should be on the inside only - otherwise any old robber could prise out the beads from outside and get into the house just by removing a pane of glass..
Back to top
 Alert Moderators
alastairreid
from United Kingdom
Thanked: 27 times
PostPosted: Fri Nov 06, 2009 9:00 pm    Post Subject:
Re: double glazing
remove the gaskets from the inside first, this should free the glass sufficiently to remove the beads.
Back to top
 Alert Moderators
IJWS15
from United Kingdom
Thanked: 6 times
PostPosted: Tue Nov 10, 2009 12:53 pm    Post Subject:
Depends on the design of the frame . . . . .
Had some in the last house where you remove the rubber strip around the inside between the glass and the frame, go outside and push the glass inwards (about 3-4mm), prise out the beads, remove the glass. Fitting is the reverse.
The ones we have now are different. Prise out beadings with broad bladed paint scraper or similar - start with the one that sits ovet the top of the others at the corner - probably a long one. Cut the self adhesive strip on the inside of the glass and remove pane. Clean off remnants of self adhesive strip. Go buy some more self adhesive strip and refint etc.
If you can see the self adhesive strip (looks like 3mm thick sponge) you have the second type. It is this self adhesive sponge that stops the late night visitors taking the glass out without waking you.
Sometimes the beads are just difficult to get out.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > DIY Disasters All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
