Shaw
Joined: 07 Nov 2009 Posts: 3 Location: United Kingdom Thanked: 0 times
Posted: Sat Nov 07, 2009 4:06 pm Post Subject: Plasterboarding weak ceiling vs cutting out and replacing |
I'm a complete newbie and won't even be attempting to do this myself... but a chunk of my living room ceiling has come down. It's the original 1920's ceiling made of plaster mixed with horsehair with a thin lime coating over the top. Apparently the ceiling was weakened by converting into the attic above and also putting halogen spotlights in. There is another big crack appearing at the centre of the ceiling.
The laths are still intact. One plasterer has recommended that he plasterboards over the entire ceiling and then skims it. Someone else insists that the whole ceiling needs to come down, including the laths and that he will then plasterboard over the ceiling joists and skim it, at a huge expense.
I'm inclined to go with option a as it's a lot less mess and also cheaper but am I just storing up trouble for myself a couple of years down the line?
Really hope someone can offer me some good advice! |
maltaron
Joined: 20 Apr 2007 Posts: 312 Location: Cornwall, United Kingdom Thanked: 3 times
Posted: Sat Nov 07, 2009 4:19 pm Post Subject: |
Taking down a lath & plaster ceiling will make a hell of a mess and the dust gets everywhere. I screw 40 x 25mm slate laths thro' the lath & plaster into the joists. (If you want a perfect flat ceiling the battens can be packed at fixing points). Plasterboard and skim and you should have no problems. |
| Back to top |
Shaw
Posted: Sat Nov 07, 2009 6:17 pm Post Subject: |
Thanks for the reply. It seems that the only benefit of cutting out the old ceiling is that it's more expensive - the second plasterer was adamant that it was the only way to do the job, but wouldn't explain why! And with plaster-boarding, I'm hopeful that the original 20's coving can be saved. |
noseall
Joined: 02 Feb 2006 Posts: 11059 Location: Staffordshire, United Kingdom Thanked: 73 times
