Author
Message
mattyuk Joined: 07 Nov 2009 Posts: 7 Location: Birmingham, United Kingdom Thanked: 0 times
Posted: Sat Nov 07, 2009 4:38 pm Post Subject: ceramic hob and double oven wiring
can i wire a ceramic hob and double oven to existing 6mm cable if so what rating rcd ? any help wud b great thanx
Back to top
If you don't want to see this advert, click here to login or if you are new click here to join free.
Aragorn84 Joined: 03 Sep 2008 Posts: 333 Location: West Lothian, United Kingdom Thanked: 26 times
Posted: Sat Nov 07, 2009 6:19 pm Post Subject:
You really need to provide more information than that.
Whats the rating of the cooker and the oven. Whats the rating of the current protective device. What are the oven and hob required to be fused at?
Back to top
Posted: Sat Nov 07, 2009 6:36 pm Post Subject:
ceramic hob is 5800 watts and double oven is 4080watts i have 6mm from cu to switch is that any good ?
Back to top
Posted: Sat Nov 07, 2009 6:42 pm Post Subject:
Do you know how the 6mm cable is routed?
I'd say that 6mm cable is a bit marginal for that load, but there is some diversity you can apply to kitchen circuits perhaps a spark can advise on that...
Back to top
Posted: Sat Nov 07, 2009 6:44 pm Post Subject:
cable is run from kitchen to garage thru walls i think
Back to top
Posted: Sat Nov 07, 2009 7:03 pm Post Subject:
thinking about keepin my gas hob but havin the electric double oven running on 6mm is that ok what type rcd
Back to top
Steve Joined: 15 Apr 2005 Posts: 12857 Location: Yorkshire, United Kingdom Thanked: 22 times
Back to top
Posted: Sat Nov 07, 2009 7:18 pm Post Subject:
thank very much the existing hob is 13 amp plug igniter and the rcd is 16 amp do i need to change it
Back to top
Posted: Sat Nov 07, 2009 7:22 pm Post Subject:
Heh if gas is an option, then its a no brainer.
Electric hubs are bloody awful things.
Back to top
Posted: Sat Nov 07, 2009 7:28 pm Post Subject:
i know but a will of a woman is hard to ignore lol so will the rcd b ok then ?
Back to top
Posted: Sat Nov 07, 2009 7:55 pm Post Subject:
MCB
Back to top
Posted: Sat Nov 07, 2009 7:57 pm Post Subject:
wylex cu with a 16 amp circuit breaker 4 the existing cooker
Back to top
