DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
Chip repair on laminate floor
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
Search this topic :: View previous topic :: View next topic
Author Message
tvern
from United Kingdom
PostPosted: Tue Oct 24, 2006 4:04 pm Reply with quote
I installed oak effect laminate flooring (Floormaster Aqualoc) a couple of months ago. I recently scratched one of the planks - a thin but deep scratch.
I don't want to replace the board because that means i have to lift up most of the floor to get to it. Can anyone advise me of how to repair it? I cant seem to find any matching fillers for the floor.
Thanks.
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
gcol
from United Kingdom
Thanked: 43 times
PostPosted: Tue Oct 24, 2006 4:52 pm Reply with quote
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 100 times
PostPosted: Tue Oct 24, 2006 4:54 pm Reply with quote
Back to top
 Alert Moderators
tvern
from United Kingdom
PostPosted: Wed Oct 25, 2006 12:33 pm Reply with quote
Thanks for your replies.
I was a bit wary about buying a repair kit off the internet, because i always end up buying the wrong colour or shade. But seeing that B&Q and other hardware stores dont seem to be stocking it, i will try my luck with them. icon_smile.gif
Back to top
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 210 times
PostPosted: Wed Oct 15, 2008 8:39 am Reply with quote
And others hate it too because of the so-called easy-click systems taking much longer to install than normal standard practical T&G's!
And for the above reason in the question: when damaged hard to repair.
Back to top
 Alert Moderators
moosele
from United Kingdom
PostPosted: Wed Oct 15, 2008 12:18 pm Reply with quote
If you have a spare board you can cut the board out with a trim saw or circular saw, cut about an 1" from the outside of the damaged board on all sides and lift the panel out. Then take your time and work round slowly lifting and cutting until all the board is out. Clean all the edges with a hoover and remove all the saw dust. Then cut the tonge off the end of the board and the lower part of the groove along the long edge. Then gule all around the edges and then lower the board in. Dont walk or put any furniture on it until the glue dries. It does work and i have done it several times on wood and laminate - used to be a wood floor fitter.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
kitchen floor (half chip board / half ply) - is chipboard OK 4 1280 Mon Oct 01, 2007 12:56 pm
Underlay - Sub floor chip board except around fire place 4 520 Thu Sep 17, 2009 6:49 pm
can i glue solid wood floor to chip board 6 700 Mon Mar 31, 2008 8:22 pm
Does chip-board floor "wear out"? 4 680 Fri Sep 18, 2009 4:17 pm
Engineered Wood Floor onto Chip Board - Do I need DPM 2 800 Wed May 30, 2007 9:19 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
