sub base for patio
15 Oct 2006
Glasgow
Starting to excavate to extend existing patio. New top surface will be 50mm woburn rumbled setts, and only have foot traffic, no vehicles.
Have read that the sub base s/b 100mm MOT Type 1, but also read that 50mm would be sufficient. I expect to find hardcore under the existing patio, but what depth would be best for the new area - it has only ever been tarmac & gravel, and was previously a driveway.
Also, existing patio height is very close to DPC level, but never had any problems with damp penetration. Wall is roughcast, rather than brick. Should I consider leaving a 100mm gap for gravel, or can I lay the setts right up to the wall, givden I've not had a problem so far? (which I know doesn't rule out a problem in the future)
Many thanks for any advice
50mm will suffice if the ground is solid, but obviously 100mm would be better.
i would leave a gravel edging
Thanks Thermo,
whilst reading through the pages on paving expert I came across details of paviour edging that removed the need for concrete haunches.
Product was Aco Borderguard. Just wondered if you/anyone had used it and is it worth the money - £5 per metre length - as opposed to using the haunches?
Cheers
