jamie473
Joined: 10 Nov 2007 Posts: 15 Location: Coventry, United Kingdom
roughcaster
Joined: 02 Aug 2007 Posts: 4046 Location: Moray, United Kingdom Thanked: 370 times
Posted: Mon Dec 29, 2008 11:55 pm |
What you have there Jamie is "Dot and Dab" plaster-boarding that's coming unstuck from the blockwork. The whole wall....It is the ultimate problem with this cheap and nasty method of cladding blockwork. I've never had a good word to say for it and never will...... I don't think there's any way to repair this "properly", other than to take all the wallboards off, strap the wall with battens and re-board it. If it was done that way in the first place, you wouldn't have the problem you have today. Dot and Dab should be outlawed,, but it's quick and cheap to do,, so it wont be.
Roughcaster.
JohnD
Joined: 15 Nov 2005 Posts: 34361 Location: Hampshire, United Kingdom Thanked: 1087 times
Posted: Mon Dec 29, 2008 11:57 pm |
couldn't you use frame screws? |
roughcaster
Posted: Tue Dec 30, 2008 12:05 am |
You could give it a try with screws/washers, countersunk slightly, (difficult though on plasterboard), to try and pull it back in tight,,, but I think ultimately, and if possible,, timber strapping and re-boarding, would be the ideal solution.,, who knows,,,,I've never had to deal with this type of problem,,,, especially with it being the whole wall too. A dreadful situation for a property less than 20 years old.
Roughcaster. |
jbonding
Joined: 04 Feb 2005 Posts: 1926 Location: Manchester, United Kingdom Thanked: 2 times
Posted: Tue Dec 30, 2008 12:55 am |
Firstly they have been applied wrong, theres not enough dabs and the back of thermal board should be given a tight coat of adhesive then dabbed and screws with big heads should be used aswell as the dabs. Without takin all the boards off the only way to fix it is cut holes similar to the one youve cut lets say 4 a board, use the screws with big heads or big washers and fix the board back to the wall and then fill the holes with drywall adhesive then patch. |
jamie473
Posted: Tue Dec 30, 2008 9:18 am |
Many thanks for the replies it's a bit of a nightmare really, as I own 75% percent of the property and a housing association own the other 25%. Building insurance is in with the rent I pay them each month, but they say the dot & dab disbonds are my problem and the insurance wont cover it. What they did do though is send one of their repairmen out to have a look and he cut out that hole and left. Still waiting from them to know if they plan to sort the hole out! |
noseall
Joined: 02 Feb 2006 Posts: 17180 Location: Staffordshire, United Kingdom Thanked: 852 times
Posted: Tue Dec 30, 2008 10:31 am |
after screwing it may pay you to supplement the fixings by squirting some of this into the void via some pre-drilled holes. |
