DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
Is Oil Based Primer OK with the Top Coat Water Based
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
Search this topic :: View previous topic :: View next topic
Author Message
planemad
from United Kingdom
Thanked: 19 times
PostPosted: Sat May 23, 2009 5:54 pm Reply with quote
As title.
I have bare wood, knots have been sealed.
Can I use oil based primer and water based satinwood as a top coat.
Or should I stick totally to water based for primer and top coat?
Many Thanks
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
oilman
from United Kingdom
Thanked: 26 times
PostPosted: Mon May 25, 2009 12:48 pm Reply with quote
try this and don't bother with primer.
I don't necessarily agree this is good for wood, but it's a quick and dirty solution.
Back to top
 Alert Moderators
Nestor_Kelebay
from Canada
Thanked: 6 times
PostPosted: Wed May 27, 2009 4:05 am Reply with quote
Planemad:
You CAN use either oil based or water based paints over either oil based or water based primers.
HOWEVER, the reason why oil based primers have better adhesion to wood is that the size of the alkyd resins found in oil based primers is very much smaller than the size of polyvinyl acetate or polymethyl methacrylate resins found in water based primers.
As a result of this tremendous difference in size, oil based primers penetrate some tiny distance into wood, and this penetration results in better adhesion of oil based primers to wood than water based primers.
The very best adhesion to wood is obtained with drying oil based primers, such as a primer that's made from boiled linseed oil. In that case, the primer consists of linseed oil molecules which are very much smaller still than alkyd resins, and penetrate comensurately deeper than alkyd resins, for still better adhesion to wood.
Water based primer or paint resins are HUGE compared to even alkyd resins that they don't penetrate AT ALL into the wood. As a result, water based primers and paints are more easily scraped cleanly off of wood. They rely entirely on the adhesion of the resin to any surface (not just wood) for adhesion, whereas alkyd resins adhere better because they penetrate into the wood and "root" themselves inside of it.
You don't need to know the rest:
In fact, one of the reasons why you thin alkyd paints with mineral spirits and linseed oil based paints with turpentine arises because of the relative size of alkyd resins versus linseed oil molecules. Since linseed oil molecules are much smaller, they have to potential to penetrate deeper into wood. Turpentine dries slower than mineral spirits, so thinning linseed oil based primers and paints allows more time for this penetration to occur.
By contrast, alkyd resins are too large to penetrate deeply into wood, and so there's no point in thinning alkyd primer with turpentine. You'd get a primer that took longer to dry, but didn't penetrate any deeper. So, it would take longer to dry, but you wouldn't get the benefit of any deeper penetration and therefore better adhesion. (THere are other reasons why drying oil based coatings are thinned with turpentine as well.)
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
water based primer/sealer over knotting solution 2 280 Wed Apr 06, 2011 3:37 pm
Aluminium Primer, Knotting Solution and Water Based Primer 6 3240 Mon Mar 29, 2010 1:21 pm
Any good water based gloss and primer? 5 140 Tue Jan 07, 2014 6:37 pm
Can I use a solvent based undercoat over water based primer? 2 2160 Wed Jul 11, 2007 9:18 am
Paint stains/reaction on water based exterior top coat 7 120 Sat Sep 22, 2012 9:18 am
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
