Foil backed plasterboard
28 Jul 2005
Bristol
Hello,
Can anyone tell me what the proper trade name is for the above.
Also what sizes it comes in and is it readily available.
Sorry, lots of questions.
Gyproc and Knauf are common trade names but generic name of foilback plasterboard is fine. Sheet sizes 2400x1200 x9.5/12.5/15 thick, all readily available from DIY sheds and BMs.
It was only three questions, so not too taxing ;)
Beat me by seconds;
For whom did the bell toll :?:
Ah but you gave the OP some links ergo much more helpful than my post. ;)
Thus, it tolls for me, as opposed to thee :LOL:
Thanks all,
Thinking about it I might use the green plasterboard which I presume would be a bit cheaper. Only need about 3 boards.
Cheers
Thanks all,
Cheers
What are you using it for? The two types of board have distinctly different uses; MR board will not prevent damp ingress whereas Duplex board provides a physical foil barrier.
