DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
baxi 105e combi
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Search this topic :: View previous topic :: View next topic
Author Message
seanmfc
from United Kingdom
PostPosted: Thu Oct 15, 2009 2:58 pm Reply with quote
hi all
i have a problem which is i have no h/w or c/h after a while the fan neon flashes up red i go to the fault section and it suggests the air pressure switch needs replacing can anyone confirm if this is correct
thanks all
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
powell30
from United Kingdom
Thanked: 123 times
PostPosted: Thu Oct 15, 2009 4:22 pm Reply with quote
Does the fan run?? If so it may well be the aps, or it might be a blocked venturi, kinked pipes etc. If the fan doesn't run then its the pcb or fan itself. I would suggest at that point you call an rgi
Back to top
The following user says thank you to powell30 for this useful post:
seanmfc (16 Oct 2009)
 Alert Moderators
seanmfc
from United Kingdom
PostPosted: Thu Oct 15, 2009 4:31 pm Reply with quote
the fan dont run we took it out and put 240v across it and it worked
Back to top
 Alert Moderators
lee32
from United Kingdom
Thanked: 6 times
PostPosted: Thu Oct 15, 2009 7:26 pm Reply with quote
check the air pressure switch either with a mutlimeter or by shorting it out. if this is okay the chances are it is pcb.
Back to top
The following user says thank you to lee32 for this useful post:
 Alert Moderators
rojaca
from United Kingdom
Thanked: 79 times
PostPosted: Thu Oct 15, 2009 7:33 pm Reply with quote
Powell30 is giving you all the correct information. It probably is aps stuck in normally open by sounds of it. However if your not competent you really shouldn't be undertaking work (as defined by gas safety regs) on your appliance.
Get an RGI in.
Back to top
The following user says thank you to rojaca for this useful post:
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2173 times
PostPosted: Thu Oct 15, 2009 8:19 pm Reply with quote
rojaca wrote:
...However if your not competent you really shouldn't be undertaking work (as defined by gas safety regs) on your appliance.
Get an RGI in.
Which is why the majority of RGI's on this forum do not give information about working of flues, fans, aps, and other safety critical items.
Back to top
 Alert Moderators
rojaca
from United Kingdom
Thanked: 79 times
PostPosted: Thu Oct 15, 2009 8:39 pm Reply with quote
think that was the point I was making and why I withheld information on testing of these items
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 2173 times
PostPosted: Thu Oct 15, 2009 8:57 pm Reply with quote
Indeed. It never fails to amaze me when I read what people do, how much time and money they spend on changing the wrong parts, and often the problem is solved by a pro for under £100 including a service.
Back to top
 Alert Moderators
seanmfc
from United Kingdom
PostPosted: Fri Oct 16, 2009 5:47 pm Reply with quote
hi all
i think i got it wrong there is not enough power getting to the fan to activate it when wiring the fan up to test it works fine the book suggests a pcb board is that right
Back to top
 Alert Moderators
seanmfc
from United Kingdom
PostPosted: Sat Oct 17, 2009 9:23 am Reply with quote
all sorted new pcb board
Back to top
 Alert Moderators
gasright
from United Kingdom
Thanked: 18 times
PostPosted: Sat Oct 17, 2009 1:14 pm Reply with quote
Wow whats next? are you going to work on an O/F appliance icon_rolleyes.gif
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 916 times
PostPosted: Sat Oct 17, 2009 1:17 pm Reply with quote
yeah just put the canary on the top jobs right icon_lol.gif icon_lol.gif icon_wink.gif
Back to top
 Alert Moderators
seanmfc
from United Kingdom
PostPosted: Sun Oct 18, 2009 6:15 pm Reply with quote
actually my mate a plumber and registered sorted the problem out so he should get the credit but thanks to all who had their say
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
baxi combi instant 105e central heating boiler 5 840 Tue Sep 08, 2009 11:28 am
Baxi 105e combi, fan problem 5 600 Wed Dec 28, 2005 7:10 pm
baxi combi boiler 105e 24 1160 Sun Sep 13, 2009 1:24 pm
Baxi combi 105e small leak - advice sought 11 1000 Mon Sep 07, 2009 5:28 pm
Baxi combi 105e instant central heating not turning off 5 560 Wed May 06, 2009 9:12 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
