DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Is there such a thing as
Goto page Previous  1, 2
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics UK
  View previous topic :: View next topic
Author Message
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Thu Oct 22, 2009 4:05 pm    Post Subject:
Reply with quote Thanks
Wonder if you'll get away with just swopping the 100mA RCD for a 30mA RCD??
The 100mA wont have been installed for protection on a TT system as everything to the left of it wont have been protected.
Back to top
The following user says thank you to Spark123 for this useful post:
STI (22 Oct)
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu Oct 22, 2009 4:09 pm    Post Subject:
it is probably seized. If you buy a new part you will see how it fits in. An MCB will be a lot cheaper than an RCBO. I don't know if they can be lubricated safely. If it was me I would probably try to lever it out. You must put pressure on the busbar to resist your pull or it might break out of the CU. The busbar is thickish copper with a plastic jacket and fairly rigid. You can take the whole assembly out but I don't think you can safely do with with incoming power connected.
I can't rember if your model has a clip to a DIN-rail as well. I think there is a tag at the bottom towards the back of the MCB to release a clip with a small screwdriver.
http://i.ebayimg.com/09/!Bb4QvpgBmk~$(KGrHqMH-CMEqt2V40FVBKyHzL6C5Q~~_12.JPG
Other brands, and the previous model of Starbreaker, fasten the MCBs to the busbar with screws so you can undo them and release the clip. This is easier but will not fit your CU.
It does not sound like a DIY job, I think you will have to save up for a pro.
Back to top
The following user says thank you to JohnD for this useful post:
STI (22 Oct)
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Oct 22, 2009 4:15 pm    Post Subject:
STI wrote:
i believe it met the requirements when it was wired up about 9 years ago.
I'm afraid your belief is incorrect.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
STI
from United Kingdom
Thanked: 1 time
PostPosted: Thu Oct 22, 2009 4:24 pm    Post Subject:
Yes each of the MCB's does have a black tab like bit on its base at the back which is covering the connection point to the busbar.
Thanks everyone for their help.
Ban all sheds as i said it was done before my time so do you think it was a shoddy job or set up like this for some other reason.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Oct 22, 2009 4:37 pm    Post Subject:
There can have been no "reason" for doing it like that - it's just shoddy work done by someone ignorant and incompetent.
__________________
Back to top
 Alert Moderators
STI
from United Kingdom
Thanked: 1 time
PostPosted: Thu Oct 22, 2009 5:04 pm    Post Subject:
Ban All sheds. Was there a requirement in the 16th edition, (is this what was in place say 9 years ago), for electric showers to be on a 30ma RCD.
If not why would whoever it was that did this bother to put a RCD in at all. Wouldnt it have been cheaper just to stick a rack of MCBs in or maybe even a 30ma RCD as it would have been cheaper than a 100ma.
I am genuinely interested in understanding why the 100ma RCD is there.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Thu Oct 22, 2009 5:14 pm    Post Subject:
The 16th edn IEE regs didn't require an RCD for a shower. Of course, if the manufacturer specified one then this over-rules the IEE regs and one had to be installed.
In anycase, a 100mA RCD does not provide any supplementary protection against direct contact, only 30mA or below and not Type S devices can be used for that.
The only time I can think of in domestics that 100mA TD RCDs were used is where there is a 30mA normal type device downstream so they will discriminate.
Back to top
STI (22 Oct)
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Oct 22, 2009 5:19 pm    Post Subject:
No.
But then there isn't one in the 17th either.
Ignorance and incompetence?
Yup.
__________________
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Thu Oct 22, 2009 5:20 pm    Post Subject:
I'll have to disagree with your comment on not having to use a 30mA RCD to comply with the 17th edn regs for bathrooms.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Oct 22, 2009 5:25 pm    Post Subject:
What's your name, Mark Coles?
__________________
Back to top
 Alert Moderators
STI
from United Kingdom
Thanked: 1 time
PostPosted: Thu Oct 22, 2009 5:29 pm    Post Subject:
If its me youre asking, No my name isnt Mark Coles
Back to top
 Alert Moderators
MarkColes
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 22, 2009 6:09 pm    Post Subject:
I agree with Spark123
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Thu Oct 22, 2009 7:27 pm    Post Subject:
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 2 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Zone 1 swivel bathroom downlighter - Such a thing ??? 12 440 Tue Apr 22, 2008 8:43 pm
I take it smoke is a bad thing? 17 1200 Sun Jan 06, 2008 8:30 pm
The strangest thing: Calling all Sherlock Holmes 12 920 Fri Oct 05, 2007 6:06 pm
Earth Sleeving - Is This A Recent Thing? 8 1000 Wed Jul 11, 2007 1:38 pm
What's the stupidest thing you've seen? 20 1140 Tue Sep 30, 2008 6:20 am
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
