DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Sanding Parquet
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
repsol
from United Kingdom
Thanked: 0 times
PostPosted: Thu Oct 22, 2009 6:22 pm    Post Subject:
Sanding Parquet
Reply with quote Thanks
Hi - first post to the forum but I've been gaining lots of useful advice before tackling 30msq of reclaimed oak parquet. The question I need an answer to is what is the maximum height difference I can expect to be able to "sand away" during the first 40-60 grit pass? I ask because I'm in the process of dry laying and acclimatising the cleaned blocks before bonding and there is quite a height difference (+2-3mm) between some of the blocks - will this much sand down or do I need to get rid of the high blocks before laying?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
woodfinishes1877
from United Kingdom
Thanked: 4 times
PostPosted: Fri Oct 23, 2009 7:47 am    Post Subject:
Grit 60 will certainly take a couple of mills off so this could work, obviously you'll then need to go over the surface with a grit 120 prior to overcoating with a finish
Not sure the thickness of the parquet but this should also be taken into account.
Hope this helps.
Ian McAslan
Back to top
The following user says thank you to woodfinishes1877 for this useful post:
repsol (23 Oct)
 Alert Moderators
WoodYouLike
from United Kingdom
Thanked: 29 times
PostPosted: Fri Oct 23, 2009 9:33 am    Post Subject:
Start with grit 40 to get as much of the height differences off and make sure you hire a better sander than the standard drum sanders most hire-centres have. A belt sander would be best.
When you've got this done, use grit 80 next. If you want to oil your floor use grit 120 for the third sanding and for varnish/lacquer you'll need a fourth sanding with 150 grit.
More info about restoring/repairing/installing original parquet flooring can be found here.
__________________
You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA.
Back to top
The following user says thank you to WoodYouLike for this useful post:
repsol (23 Oct)
 Alert Moderators
repsol
from United Kingdom
Thanked: 0 times
PostPosted: Fri Oct 23, 2009 11:46 am    Post Subject:
Parquet Sanding
Blocks are between 25-30mm so should be fine to take off a few mm - just wasn't sure whether a sander would take that much off. Planning to finish with hardwax oil so will make 120 the last sand before finish.
Thanks for the advice
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Best Method for Sanding Parquet Floor 7 8620 Wed Aug 15, 2007 1:09 am
A quick parquet floor sanding question...... 5 580 Mon Jul 28, 2008 4:19 pm
How to remove 'stripes' after sanding parquet flooring 9 720 Sun Apr 13, 2008 3:48 pm
Wishbone parquet flooring sanding 2 760 Sat Sep 08, 2007 9:43 am
SANDING PARQUET 2 7680 Mon Mar 29, 2004 1:09 am
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
