DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Advice re. Flexi (Tap) Connectors
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
kingarthur
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 24, 2009 7:31 pm    Post Subject:
Reply with quote Thanks
Want some advice. I am replacing an electric shower and need to put in some new plumbing for the mains water supply down from the loft. Should not be much of a problem but to ease some access problems is it ok to use some short flexible connectors (with 15mm compression joint on each end) as part of the pipework.
If yes, then could I use one at the end of the run to actually connect to the shower inlet pipe? (this would help considerably.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
muggles
from United Kingdom
Thanked: 27 times
PostPosted: Sat Oct 24, 2009 8:00 pm    Post Subject:
Flexis will considerably reduce the flow to the shower due to their narrow internal diameter, and whilst connecting several in series would theoretically work do you really want to have that many inaccessible joints inside your wall? The potential for leakage is high.
If you must use something other than copper, go to a merchants and get yourself a 3m length of Hep2o plus any fittings you might need. These fittings will also connect onto copper. Depending on what shower you have, you may well find that you need to have a copper tail coming out the wall and a compression fitting to attach it to the shower.
Back to top
 Alert Moderators
kingarthur
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 24, 2009 8:09 pm    Post Subject:
Thanks for the reply.
Probably didnt make myself clear, majority of run will be 15mm copper pipe down from loft I was only intending to use a flexi pipe for the last connection on to the shower (for access reasons).
How much difference will the smaller bore make to the flow. If this is going to make a big difference I will work around it and use standard copper fittings / connectors.
Back to top
 Alert Moderators
muggles
from United Kingdom
Thanked: 27 times
PostPosted: Sat Oct 24, 2009 8:15 pm    Post Subject:
Depends a little on the water supply, in general mains will be affected less by the reduced diameter than tank-fed, due to the higher pressure of mains, but either way if at all possible I would advise using copper. Another disadvantage of flexis is that they are liable to kink if subjected to prolonged compressive forces such as may be experienced when pushing it back into the wall when you've made your connection (you almost certainly won't be able to connect the flexi straight onto the shower as this will kink quite quickly)
Back to top
The following user says thank you to muggles for this useful post:
kingarthur (24 Oct)
 Alert Moderators
kingarthur
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 24, 2009 8:19 pm    Post Subject:
Ok thanks again.
Have never used 'hep20' before as have always been worried about the effectiveness and reliability of push fit systems. Is this system ok to use on mains fed water supply?
Also is it readily available in plumbers merchants, more expensive etc?
Back to top
 Alert Moderators
Goldspoon
from United Kingdom
Thanked: 9 times
PostPosted: Sat Oct 24, 2009 9:00 pm    Post Subject:
kingarthur wrote:
Ok thanks again.
Yes is fine - fit properly and all is well. Whole houses plumbed in this stuff nowadays.
Readily available yes.
Back to top
The following user says thank you to Goldspoon for this useful post:
kingarthur (24 Oct)
 Alert Moderators
muggles
from United Kingdom
Thanked: 27 times
PostPosted: Sat Oct 24, 2009 9:52 pm    Post Subject:
There are very few situations in which Hep2o cannot be used. I won't go into them now because they aren't relevant to what you're doing. Pipe is about the same price, fittings tend to be more expensive but it'll give you the flexibility I think you're after
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
basin flexi tap connectors 2 160 Fri Oct 26, 2007 6:49 pm
Flexi tap tail connectors 6 280 Sun Dec 02, 2007 7:08 pm
3/8" flexi tap connector 7 300 Thu Apr 17, 2008 9:57 pm
Connecting a flexi with a female screw thread to 15mm 5 280 Mon May 12, 2008 6:05 pm
Flexi pipe needed? 8 240 Wed May 21, 2008 5:35 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
