DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
moving a switch
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics UK
  View previous topic :: View next topic
Author Message
chatfim
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 27, 2009 5:28 pm    Post Subject:
moving a switch
Reply with quote Thanks
can anyone help?
in my garage (which has it's own separate fuse box) i have a partition. in the front part is a single bulb, and a switch that controls both this light and the light in the back half of the garage (a flourecesent tube).
what i want to do is to move the switch, so could i do it thus:
1 turn off power
2 remove switch, join cables with a connecting block (red to red, black to black) and put a blanking plate in.
3 open up the tube holder, and run the red lead, via conduit down to a (new) switch in the back part of the garage, then back up to the light fitting.
will this switch now control both lights, or do i still need the one in the front part of the garage
i hope this is clear..........
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Oct 27, 2009 5:51 pm    Post Subject:
Why not just rewire it rather than start joining cables - aren't they all on the surface and accessible?
Where does the lighting loop run - at the lights or the switch?
Wouldn't 2-way switching make most sense, so you could work the lights from the back and the front?
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
chatfim
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 27, 2009 6:36 pm    Post Subject:
2-way switch also sounds complicated.
on reflection, can i just extend the cables via conduit and put the switch where i want?
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Tue Oct 27, 2009 7:36 pm    Post Subject:
electrics:lighting
Yes, but it's not the best way, and you really should take the trouble to learn about what you're fiddling with, rather than just connecting up wires with absolutely no idea of what's going on.
http://www.diynot.com/forums/viewtopic.php?p=60849#60849
http://www.diynot.com/forums/viewtopic.php?p=75416#75416
__________________
Back to top
The following user says thank you to ban-all-sheds for this useful post:
chatfim (27 Oct)
 Alert Moderators
chatfim
from United Kingdom
Thanked: 0 times
PostPosted: Tue Oct 27, 2009 8:06 pm    Post Subject:
thanks for that, and you're right of course, and i shall endeavour to lean more.
however, up to this point, all but the very simplest of wiring tasks has been a bit of a mystery, so apart from the very obvious, i've steered clear. mostly i wanted to know if it would be safe, but i'll take your advice and buy a book, so next time............
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Tue Oct 27, 2009 11:53 pm    Post Subject:
We can help, don't lose heart - yet!
Turn the garage power off, unscrew the lights switch and take a photo of the back of the switch so we can see the way the wires are connected.
Should then be able to let you know how to do 2-way switching or other solutions.
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
chatfim
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 28, 2009 6:01 am    Post Subject:
ok, will do, but not home 'till friday pm,
talk later, and thanks (in advance icon_biggrin.gif )
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Moving a bathroom light switch 3 420 Wed Jun 15, 2005 11:16 pm
Moving a light switch to stub wall query? 9 260 Tue Nov 04, 2008 9:14 pm
Electrical switch & moving oven question 5 400 Sun Oct 05, 2008 8:41 pm
Moving a cooker Switch 3 640 Wed Jun 01, 2005 2:15 pm
Moving 1 light switch out of 3 gang light switch (with pic) 2 400 Tue Jan 23, 2007 1:16 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
