Joined: 15 Dec 2006 Posts: 2388 Location: United Kingdom Thanked: 34 times
Posted: Thu Oct 29, 2009 9:36 pm Post Subject:
Any more info on this one?
Intermittent EA fault
COČ spot on 9.7% high 9.1% low
Spark gap 4.5mm
condense trap cleaned
Not working on arrival (EA fault) very poor spark, cleaned trap, closed electrodes, checked continuity on flue ad o/h stas then worked fine, called in tonight EA fault again!?
Joined: 05 Feb 2009 Posts: 89 Location: Aberdeen, United Kingdom Thanked: 13 times
Posted: Fri Oct 30, 2009 12:18 am Post Subject:
42CDi has a square WB5 heat exchanger the round WB3 heat exchanger is found on cheaper models like the Si, i Junior and Ri.
Gas pipework is undersized but the boiler should still work fine with 15mbar inlet pressure just not give full performance.
Check the bearing plate hasn't split in the air/gas manifold.
Check both gas valve coils they should read between 120 and 200 Ohms
If the boiler is connected to an old gas pipe it may be worth checking the gas valve inlet filter.
You can check ignition by turning on permanent spark in service mode. Hold service button till it turns orange (roughly 10 secs) press eco button till 8F is displayed, press chimney sweep button, press eco till 1 is displayed, press and hold chimney sweep till ignition starts DO NOT RUN FOR MORE THAN 2 MINUTES. To turn off press eco till 0 is displayed, press and hold chimney sweep button.
Removed siphon bowl and pint of coondense it fired up!
Blew down condense pipe, all clear
Washed siphon trap and tube refitted switched on and no ignition spark..Gas OK
Closed spark gap down to 3-4mm and away it went.
Ran heating and hot water, left heating running.
Waiting for the knock on the door.......................
Oop's am I bad 8F is in service level 2 which you get to by going into service level 1 (holding service button for 10 secs) then pressing and holding eco and holiday buttons for 3 secs.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
