DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
house bricks too small?
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Fri Oct 30, 2009 4:13 pm    Post Subject:
Reply with quote Thanks
I need 4 bricks to patch a hole in an internal wall.
I got some that were left over from a wall at nans about 15 years ago ( cleaned out form nan's garage.. ) but they are too small for some reason..
the bricks are 215 x 65 ( face size.. didn't measure the depth.. ) with lots of 12mm ish holes in them..
the old ones are 220 x 70... and seem to be solid ( can't see any "frog" in the bits I took out.. ).. they are also kind of black inside if that makes any difference?
I'm guessing that it's something to do with pre / post metrication..?
is it worth trawling round the builders merchants and sheds with a tape measure, or would skip diving / freecycle be my best bet?
__________________
If you make everything idiot proof, evolution will just make a better idiot.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
stuart45
from United Kingdom
Thanked: 7 times
PostPosted: Fri Oct 30, 2009 4:26 pm    Post Subject:
The small ones are metric, but for an internal wall to be plastered just make the joints a bit bigger.
Back to top
The following user says thank you to stuart45 for this useful post:
ColJack (30 Oct)
 Alert Moderators
matt204
from United Kingdom
Thanked: 1 time
PostPosted: Fri Oct 30, 2009 4:38 pm    Post Subject:
Yep, metric bricks are quite a bit smaller (215x102x65mm). I think it should be quite easy to find imperial ones, they will just cost more. I have got loads in my garden as I have just removed a wall. If you really need them I shall be visiting the Midlands next weekend.
Back to top
The following user says thank you to matt204 for this useful post:
ColJack (30 Oct)
 Alert Moderators
hotrod
from United Kingdom
Thanked: 10 times
PostPosted: Fri Oct 30, 2009 4:48 pm    Post Subject:
Sounds like your nan's got the old imperial bricks Col. Commonly, bricks traditionally come in two sizes, 2⅝" and 2⅞", which today in metric translates to 65mm and 73mm. Most bricks are still manufactured in both sizes.
Back to top
The following user says thank you to hotrod for this useful post:
ColJack (30 Oct)
 Alert Moderators
ColJack
from United Kingdom
Thanked: 129 times
PostPosted: Fri Oct 30, 2009 6:41 pm    Post Subject:
so it's a trip round the sheds with a tape measure then?
or look out inthe local area for skips with some bricks in..
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
New small house construction - need advice 3 260 Mon Jan 23, 2006 11:41 pm
Small crack on exterior wall of house 2 540 Tue Nov 08, 2005 11:55 am
Outdoor tiling to small wall 4 420 Fri Jan 26, 2007 11:00 pm
Opinion on blocking up small flue 6 460 Fri Dec 08, 2006 1:06 pm
Lowering the concrete floor in a small room 2 360 Fri Feb 09, 2007 11:43 am
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
