DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Boiler troubleshooting - where to draw the line
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
lucozadenrg
from United Kingdom
Thanked: 0 times
PostPosted: Sat Oct 31, 2009 5:29 pm    Post Subject:
Reply with quote Thanks
HI, and apologies in advance if I get it wrong with my first post. I have checked your wiki and the FAQ and links as well as many other posts. My simple question is where is the line drawn on what I can and can do myself to my boiler? I should add that I use a healthy does of common sense so my example is:
1) I have an intermittent fault on a glow worm Ultimate 30FF (gets as far as running fan, sometimes spark, 'clonk' from gas valve, spark, pilot and ignition or sometimes just flue fan runs forever with no attempt at ignition)
2) When it fails next I am more than comfortable (I am an Electrical and Electronic Engineer) to make the electrical checks in the fault finding chart.
3) SHould it point to PCB failure I am also more than capable to change the PCB this does not necessarily make me a legally 'competent' person to do though however.
It would be great to understand if anyone knows the position for the above(also how common PCB failure is in this type of boiler - its about 8 years old)
My broad view is that anything that does not directly touch or interfere with the gas or exhaust would be OK but I have no real basis for this. (If in this example I screwed up the PCB replacement then the boiler would just not work.
As a further example if the fault finding pointed to a faulty air pressure switch or a faulty soleniod then whilst I am still comfortable I could replace these with ease, since they directly affect either the gas or exhaust then I would need a Gas Safe certified person to make these changes.
Would be great to understand where the line is drawn.
thanks L
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
kirkgas
from United Kingdom
Thanked: 32 times
PostPosted: Sat Oct 31, 2009 6:28 pm    Post Subject:
your fault is likely to be air pressure switch related, but that is neither here nor there, your comments about changing a pcb as it isnt gas related, could be wrong (dont know this exact boiler) but sometimes when a board is changed the gas rate needs to checked/reset by a potentiometer (dodgy spelling), however the air pressure switch merely confirms enough air is passing through the fan (via a venturi to the pressure switch) to remove products of combustion to outside.
i dont know you so dont wish to offend by saying please ensure you are fully aware of what you intend to work on to ensure you and yours are ok
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 190 times
PostPosted: Sat Oct 31, 2009 7:47 pm    Post Subject:
In addition to Kirk's comments, there isn't really a way to test the pcb unless you have an electronic test lab, and all the relevant data of the pcb.
__________________
Don't feed the troll.
Back to top
 Alert Moderators
jt1
from Ireland
Thanked: 0 times
PostPosted: Sat Oct 31, 2009 8:25 pm    Post Subject:
Would agree, while you sound as if you are competant ,if you have to take the cover off the boiler you should be registered.Lost count of the amount of times i have been called to boilers after someone else has had a go and messed up!!.Thankfully things have changed over here now.
Back to top
 Alert Moderators
lucozadenrg
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 01, 2009 4:20 am    Post Subject:
thanks guys. bizarely as soon as I test the volatge between air pressure switch and neutral the boiler fires into life so i guess the switch or pcb is done. just need to find someone who isnt 'too busy' to come and sort it for me!
Back to top
 Alert Moderators
WDIK
from United Kingdom
Thanked: 31 times
PostPosted: Sun Nov 01, 2009 7:06 am    Post Subject:
its an aps problem, but a good dose of common sense is worthless compared to knowing what your doing icon_wink.gif
__________________
Association of Registered Gas Installers (ARGI)
Back to top
The following user says thank you to WDIK for this useful post:
lucozadenrg (1 Nov)
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Sun Nov 01, 2009 8:26 am    Post Subject:
don't mention testing it with a meter the mods don't like it
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
lucozadenrg
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 01, 2009 1:25 pm    Post Subject:
cool thanks to all for advice and help, will keep trying and hope I can get someone to take a look this week!
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Sun Nov 01, 2009 2:07 pm    Post Subject:
As boilers go this is a very simple one and the fault a typical simple fault which most boiler engineers would be able to manage.
The only problem you could have is finding someone competent who is not going to overcharge you. Most are not into ripping anyone off but a very few might.
__________________
ARGI Registered Engineer
Back to top
The following user says thank you to Agile for this useful post:
lucozadenrg (1 Nov)
 Alert Moderators
bengasman
from United Kingdom
Thanked: 190 times
PostPosted: Sun Nov 01, 2009 2:58 pm    Post Subject:
You could post the job on here with a rough indication of your area; at least you would have a fair idea of the kind of guy that is coming.
I would expect this job to cost less than £430.
__________________
Back to top
The following user says thank you to bengasman for this useful post:
lucozadenrg (1 Nov)
 Alert Moderators
lucozadenrg
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 01, 2009 3:26 pm    Post Subject:
thanks again for all the help, i'll have one more go with someone local (recommendation from neighbour, with all the necessary credentials and has recently sorted out the same boiler in the neighbour's house) and then post back here if no luck. Maybe I have been unlucky and it is just a really busy couple of weeks!
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Sun Nov 01, 2009 3:31 pm    Post Subject:
Most boiler engineers aim to visit the same or next day if a boiler is not working.
I would expect the cost to be less than £99 apart from parking. congestion charges etc!.
But there is no substitute for being in front of the boiler to diagnose faults!
__________________
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 190 times
PostPosted: Sun Nov 01, 2009 3:32 pm    Post Subject:
Lucky you, quite handy if you can use the neighbours to testdrive your plumber. icon_lol.gif
By the way, when I mentioned below £430, that was an understatement.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
DP can I draw on your vokera excel knowledge? 2 500 Sat Dec 03, 2005 9:01 am
Troubleshooting: Worcester CDi boiler power supply 8 160 Sat Aug 16, 2008 6:15 pm
THERMOSTATIC SHOWER VALVE TROUBLESHOOTING 4 300 Sat Nov 10, 2007 5:25 pm
Troubleshooting motorized Valve? 11 680 Mon Oct 08, 2007 10:46 am
Heat Line Vizo boiler 5 10240 Sun Mar 04, 2007 11:02 am
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
