DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Failed tiling/plasterboard
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
patrick29
from United Kingdom
Thanked: 0 times
PostPosted: Sun Nov 01, 2009 1:21 pm    Post Subject:
Reply with quote Thanks
Any one out there that can give me some good advice please. My house is about twelve years old and the internal walls on the first floor are made up of egg-box like plasterboard. The builders had tiled the en-suite directly onto the plasterboard and I had to change it last year because of a leak. I replaced the old board with new, tiled it with good quality products and fitted a new cubicle that sits on a 1100 x 800 solid ceramic/resin base. I've just found that that the unit is leaking where the cubicle and tray meets the wall, probably in the corners. Obviously the tiler has not used enough sealant.Consequently the plasterboard has failed right around the first row of tiles. I've stripped out the wet plasterboard and tiles to let the timber dry out - I don't want to knock the tiles off and start from scratch with aqua-panel, so I was wondering if it's possible to replace the old plasterboard with aqua-panel up to the dry plasterboard, seal the joints with tape and waterproof tile adhesive and re-tile over that. If so, my concern then is that as the aqua-panel is porous, if this happens again I can't afford for the timber frame to become comprised so I want to protect that. Finally, any tips on the best shower trim to use between the tiles and the tray - I would prefer a one piece strip rather than using two sections. Any pro advice greatly received. Thanks
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
LJW61
from United Kingdom
Thanked: 35 times
PostPosted: Sun Nov 01, 2009 7:40 pm    Post Subject:
Doesnt matter if the base is porous as the tile adhesive & grout are fully waterprof when dry icon_wink.gif
Back to top
The following user says thank you to LJW61 for this useful post:
patrick29 (2 Nov)
 Alert Moderators
Spr0cket
from United Kingdom
Thanked: 1 time
PostPosted: Tue Nov 03, 2009 8:58 pm    Post Subject:
Careful on how you interpret the term waterproof. This simply means the grout or adhesive will not break down or fail when exposed to regular submersion or prolonged moisture. It does not mean it is a barrier to moisture penetration ...
Only really long term solution is to tank the wall, from a height that water application would be typical (say 1 to 1.5 mtr) down onto top of the shower base, thus any moisture that passes to tile back can only reach the tanked surface which is non water permeable. This moisture with gravity will run down to the taped shower tray, over the edge and into the trays usual drainage system.
You can reapply board, but it's likely that the water is entering from anywhere up the tiled wall surface, so applying a moisture barrier at the bottom will likely simply prolong the next failure further up the tiled surface. Also as you've found, once that moisture gets back there, the plasterboard being as "sucky" as it is will normally just keep pulling it through.
The only other true solution would be to remove the existing grout, and regrout using an epoxy based grout. Which whilst being messy and trickier to apply / clean up than regular grouting ... does provide a sealed grout layer, which, assuming tile surfaces are sealed or glazed to the epoxy grout join, will not allow further moisture to penetrate.
Back to top
The following user says thank you to Spr0cket for this useful post:
patrick29 (5 Nov)
 Alert Moderators
patrick29
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 05, 2009 9:53 pm    Post Subject:
Thanks Spr0cket, sound advice which tallies with the research I have done so far. Don't really want to hack off up to a metre and start again, but I know it's time and money down the pan if I take a chance, do a localised repair and it leaks further up the wall. I'm certain that the problem has arisen due a faulty seal around the trim as the plasterboard was only really wet in the corners and not from above the first row of tiles. So I really am in two minds as to what to do. Had a visit from a tiler today who suggested repairing the wall with marine ply and tiling over that. Not so sure of the effectiveness of such a remedy - never seen that one during my research. Any one got any views on that? Additionally, this leak has left black mould / mildew patches on the back surfaces of the dry plaster boarding and the wooden battens. Any one know an effective remedy to properly clean and kill that? Thanks.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Failed 5:1 Mist coat 9 800 Sat Nov 17, 2007 12:29 pm
Tiling, bare plasterboard or with a skim of plaster 12 1400 Fri Nov 18, 2005 4:23 pm
Newly skimmed plasterboard, preparation for tiling 4 820 Tue Sep 13, 2005 8:39 pm
Is there a minimum thickness for plasterboard when tiling 10 4620 Sun Sep 18, 2005 8:27 pm
Tiling on plasterboard. 2 740 Sun Nov 21, 2004 11:44 am
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
