DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
New wooden flooring issues
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
marcosscriven
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 03, 2009 12:53 pm    Post Subject:
Reply with quote Thanks
Hi there
I have taken down a couple of partition wall in my flat, and now have an open plan room 4m x 11m. There's an existing softwood floor on joists.
Unfortunately the joists change directly halfway; at the front they go side to side (so the boards are lengthways), and the back half they go front to back (and the boards go side to side).
I'd like the new boards all to go in one direction.
1) Is there some reasoning behind choosing the direction of laying? I think lengthways may accentuate the length of the room, and maybe make it look narrower, so veering towards side to side (along the shorther length).
2) Once I've chosen, how would I lay in all one direction? I'm guessing some kind of boarding, either on top of the existing floorboards, or directly onto the joists.
3) If I go with the above, what happens if a pipe leaks? Do I just take out one board, cut the boarding, or do I have to take out a whole board?
I'm going for engineered T&G as it will be partly an open plan kitchen.
Marcos
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Chri5
from United Kingdom
Thanked: 28 times
PostPosted: Wed Nov 04, 2009 9:18 am    Post Subject:
1- Run flooring in the direction of the windows
2- Board required between soft wood and new flooring which will allow the new flooring layer to run in the same direction as the old. Your need to use 6mm + plywood fixed at 200mm in all directions
3- I'd suggest you put a trap door in, say an alcove area, If you use tonge tite screws for fixing you will be able to remove the new flooring layer to access the trap door. If you intend to bead or scotia the expansion gap (rather than taking off all the skirting) then it makes sense to cut them to allow removal should you ever have to access the sub floor void.
Prudence would suggest you make sure all sub floor services are of a decent life span before doing the floor.
__________________
Please note compliance for Part P, LABC and 17 Edition.
Back to top
The following user says thank you to Chri5 for this useful post:
marcosscriven (4 Nov)
 Alert Moderators
marcosscriven
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 04, 2009 9:30 am    Post Subject:
re 1) Sorry to be dumb, but do you mean parallel or perpendicular to the windows? I assume parallel. In my case there are windows both at the end and side, so if I have all the boards in one direction, one or the other is going to be 'wrong'. What the reasoning behind this anyway?
re 3) Having plumbing re done, and much of the elecrics will be in the ceiling and dropping down.
Back to top
 Alert Moderators
Chri5
from United Kingdom
Thanked: 28 times
PostPosted: Thu Nov 05, 2009 10:42 am    Post Subject:
The light source tends to have the flooring ends towards it.
So a through room with a window at each end will have the flooring run from front to back.
If the flooring was the otherway any ridges or cupping of boards becomes very visible. Your situation with windows to side means that some light will be across the boards rather than down the length.
I'd go with the windows that provide the majority of light.
__________________
Back to top
marcosscriven (5 Nov)
 Alert Moderators
marcosscriven
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 05, 2009 10:52 am    Post Subject:
Ok, that works on both counts then, as the biggest windows, which are south facing, are also facing across the narrower dimension.
One other thing - would it be better to completely remove the current floorboards, and nail the plywood directly into that?
I'll be taking most of them up anyway to install soundproofing.
Marcos
Back to top
 Alert Moderators
Chri5
from United Kingdom
Thanked: 28 times
PostPosted: Thu Nov 05, 2009 2:48 pm    Post Subject:
If you spec 22mm flooring then that is structually sound enough to fix direct to the joists.
Under no cirumstances use chipboard, it doesn't allow enough grip of nails if your intention is a hidden nail fix.
Since the old boards are coming up, your choice. Put them back down and layer over plywood or buy thicker plywood sheeting and lay that as the sub floor betwwen joist and new flooring system.
In a flat I'd tend to suggest the more mass there is between the floor and the neighbours below the better heat and sound proofing will be.
__________________
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Loft flooring/Insulation - Condensation issues 4 2740 Mon Apr 25, 2005 4:08 pm
Real wood onto concrete. Floor height issues? 7 800 Fri Feb 23, 2007 12:41 pm
Any issues with nailing AND glueing a wood floor? 5 640 Thu Feb 02, 2006 9:15 am
Cutting Architrave? (for wooden flooring) 10 860 Thu Aug 10, 2006 11:15 am
WOODEN FLOORING ON EXISTING FLOORBOARDS 3 640 Wed Jul 12, 2006 9:38 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
