DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dry lining should I insulate first?
Post new topic   Reply to topic    DIYnot.com Forum Index > Building
  View previous topic :: View next topic
Author Message
eyespy999
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 04, 2009 11:56 pm    Post Subject:
Reply with quote Thanks
Hi there.
I have built a conservatory on my semi detatched house and my neighbour and I share a party wall on the connected side. We have both built conservatorys at the same time.
The party block wall is 9 inch thick and on my side I want to dry line. As it is not an external wall can I just board onto this wall or should I insulated first batten off then board onto the battens?
On the other two walls these are outer concrete block cavity with inner thermalite blocks. Again should I insulate or dot and dab straight onto the blocks?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
noseall
from United Kingdom
Thanked: 72 times
PostPosted: Thu Nov 05, 2009 6:00 pm    Post Subject:
There's not much point insulating a connie as most of the heat is lost through the roof and the glazing. I did insulate my walls though, simply to prevent cold spot occurring.
Back to top
The following user says thank you to noseall for this useful post:
eyespy999 (5 Nov)
 Alert Moderators
eyespy999
from United Kingdom
Thanked: 0 times
PostPosted: Thu Nov 05, 2009 10:22 pm    Post Subject:
Thanks noseall
How did you insulate and what products did you use. A friend of mine has suggested foil backed plasterboard for dot and dab. Not really sure the next step. Thanks
Back to top
 Alert Moderators
noseall
from United Kingdom
Thanked: 72 times
PostPosted: Fri Nov 06, 2009 3:25 pm    Post Subject:
As a token gesture you could poke some insulation down the cavities if you have access. Insulating the solid 9" wall may afford you some sound insulation also.
The 9" solid wall could be dabbed with insulation backed boards, though i can't envisage it doing a lot more than simply dabbing 12.5mm plain boards.
Foil backed boards can not be dabbed (they need to be mechanically fixed) and are used as a vapour check only. They offer very little insulation value.
Back to top
eyespy999 (7 Nov)
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Building All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
How to insulate under uPVC cladding 2 240 Thu Sep 11, 2008 8:09 pm
Insulate solid wall or not 3 500 Tue Oct 14, 2008 12:47 pm
Chalet drafty floors - insulate? 4 560 Tue Feb 12, 2008 7:02 pm
How to Insulate the Dry Container? 2 740 Thu Aug 23, 2007 6:16 am
How to insulate and damp proof a solid wall? 4 1000 Fri Jul 07, 2006 8:29 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
