dogdog
Joined: 05 Nov 2009 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Thu Nov 05, 2009 10:15 pm Post Subject: double glazing |
how do i get the external glazing beads the rectangular ones out of a double glazed frame to replace the unit |
WHJOHNSON
Joined: 17 Apr 2008 Posts: 8 Location: United Kingdom Thanked: 0 times
Posted: Fri Nov 06, 2009 8:45 pm Post Subject: |
The removable glazing beads should be on the inside only - otherwise any old robber could prise out the beads from outside and get into the house just by removing a pane of glass.. |
alastairreid
Joined: 21 Nov 2008 Posts: 1701 Location: Ayrshire, United Kingdom Thanked: 28 times
IJWS15
Joined: 18 Oct 2006 Posts: 716 Location: Staffordshire, United Kingdom Thanked: 6 times
Posted: Tue Nov 10, 2009 12:53 pm Post Subject: |
Depends on the design of the frame . . . . .
Had some in the last house where you remove the rubber strip around the inside between the glass and the frame, go outside and push the glass inwards (about 3-4mm), prise out the beads, remove the glass. Fitting is the reverse.
The ones we have now are different. Prise out beadings with broad bladed paint scraper or similar - start with the one that sits ovet the top of the others at the corner - probably a long one. Cut the self adhesive strip on the inside of the glass and remove pane. Clean off remnants of self adhesive strip. Go buy some more self adhesive strip and refint etc.
If you can see the self adhesive strip (looks like 3mm thick sponge) you have the second type. It is this self adhesive sponge that stops the late night visitors taking the glass out without waking you.
Sometimes the beads are just difficult to get out. |
