DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
CONDENSATION FROM CONCRETE FLAT ROOF
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering
  View previous topic :: View next topic
Author Message
GAZZA26
from United Kingdom
Thanked: 0 times
PostPosted: Fri Nov 06, 2009 5:54 pm    Post Subject:
Reply with quote Thanks
HI, I HAVE A SLOT EXTENSIONS ATTACHED TO OUR KITCHEN. ITS A CONCRETE ROOF BUT GUESSING THE AGE OF THE BUILDING (1960) IT ISNT INSULATED. THE TOILET PART OF THE EXTENSION IS STARTING TO ATTRACT CONDENSATION AND MOULD ON CEILING, ALL THE OTHER PART OF THE EXTENSION IS OK. IM GUESSING THIS IS BECAUSE OF THE CONCRETE ROOF, IVE HAD THE FLAT CONCRETE ROOF FELTED ON THE OUTSIDE SO I HOPE ITS NOT LEAKING. HOW CAN I STOP THIS CONDENSATION PROBLEM, PLEASE HELP.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
maaaaaaaaat
from United Kingdom
Thanked: 3 times
PostPosted: Fri Nov 06, 2009 6:49 pm    Post Subject:
Re: CONDENSATION FROM CONCRETE FLAT ROOF
you need warmth and ventilation.
Back to top
The following user says thank you to maaaaaaaaat for this useful post:
GAZZA26 (7 Nov)
 Alert Moderators
ban-all-sheds
from United Kingdom
Thanked: 78 times
PostPosted: Fri Nov 06, 2009 7:06 pm    Post Subject:
And you need to stop shouting.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
GAZZA26
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 07, 2009 9:44 am    Post Subject:
How do i go about fixing this problem?
Back to top
 Alert Moderators
roy c
from United Kingdom
Thanked: 10 times
PostPosted: Sat Nov 07, 2009 9:56 am    Post Subject:
Can you get us a pic up? Its hard trying to visualise it, you might be able to cross batten it and fill the gaps with polystyrene,and then put poly-backed plaster board over the top..Have you got good ventilation in the room?
Back to top
 Alert Moderators
GAZZA26
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 07, 2009 10:00 am    Post Subject:
I have a window in the toilet and one exterior air brick near bottom, would putting an air brick near top of wall would help. I have abut 20 cm gap from ceiling to window is this enough gap to put insulation in
Back to top
 Alert Moderators
roy c
from United Kingdom
Thanked: 10 times
PostPosted: Sat Nov 07, 2009 10:18 am    Post Subject:
That would be plenty. The battens are 1" thick and the poly-backed p/board could be from 22mm up to 2or 3 inches. But 22mm would be sufficient. Make sure the battens are 2x1" tanalised roofing battens...Another air-brick higher up wouldn't do any harm, but I think when you have equalised the ceiling to the same warmth of the room you should be ok, Hope that makes sense? icon_wink.gif I think its a case of hot air or warm air hitting cold....
Back to top
 Alert Moderators
GAZZA26
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 07, 2009 12:25 pm    Post Subject:
I HAVE JUST MOVED SOME STUFF FROM AROUND THE TOILET AND NOW FOUND MOULD AROUND THE TOILET WALL ASWELL, WOT SHOULD I DO
Back to top
 Alert Moderators
roy c
from United Kingdom
Thanked: 10 times
PostPosted: Sat Nov 07, 2009 1:07 pm    Post Subject:
give it a wash down with bleach and dry it off then dont put any more stuff around the toilet.It seems like a classic case of condensation,(black mould on the bottom corner of the walls....)
Back to top
 Alert Moderators
GAZZA26
from United Kingdom
Thanked: 0 times
PostPosted: Sat Nov 07, 2009 1:09 pm    Post Subject:
IF YOU KNOW WHO DO I NEED TO CONTACT TO GET THIS SORTED (TRADESMAN) AND HOW MUCH WOULD IT COST
Back to top
 Alert Moderators
roy c
from United Kingdom
Thanked: 10 times
PostPosted: Sat Nov 07, 2009 1:29 pm    Post Subject:
Back to top
The following user says thank you to roy c for this useful post:
GAZZA26 (7 Nov)
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plastering and Rendering All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Dry lining and condensation 2 400 Tue Aug 19, 2008 6:44 am
condensation on internal walls 4 620 Tue Jan 20, 2009 12:23 pm
Condensation on bedroom wall creating damp and mould 3 500 Tue Dec 30, 2008 8:23 pm
Flat rendering over terolean coated wall 3 340 Sat May 31, 2008 5:58 pm
Time To Plaster Flat Wall 15 700 Sun Aug 03, 2008 6:42 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
