Lead flashing repair
2 Dec 2009
Hi all
Ok, I have a leak coming through the ceiling on a bay window. Checked the outside and the flashing is loose. My first thought was just to wedge the flashing back in and repoint the mortar / use mastic but on closer inspection there is insufficient lead sheet to push back into the joint and wedge. Only between 5-10mm has been turned back into the mortar. Could I just get a second roll of flashing and fit this into the wall so that it sits over the original flashing to provide waterproofing?
What is the best way to repair this or will I have to get someone to replace the whole lot over the bay window?
Steve
a roll of 225mm code 4 lead dressed in and over the existing apron will suffice.
225 is a bit wide/expensive :idea: there should be a separate cover flashing over the upstand anyway . :confused: 150mm code 4 25 mm for turn 5inches hanging down :oops:
Hi. When using sheet lead to cover a roof it is good practice to leave a 4" up stand at the wall abutment and fit cover flashing, say 150 mm code 4 sheet lead, turn an edge at 30 mm over the edge of a bench and simply fit it in the chase you cut with a disc cutter. This method allows any settlement / shrinkage of the roof movement without stressing the joint into the masonry. Just that which you are proposing for your repair. Good Luck
