| Author |
Message |
mickroyds
Joined: 29 Jan 2010 Posts: 84 Location: Sheffield, United Kingdom Thanked: 5 times
Posted: Tue Mar 23, 2010 2:17 pm |
I have installed 22mm F & R away from the boiler and used 22mm T's with a 15mm offsets to feed each rad individually, the rads are within 3 mts of the T's, people that have seen it suggested 10mm would have been quite adequate and easier to work with to make the pipework discreet.
What does the team think ?
The jobs done but i'm curious.
Cheers Mick. |
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
powell30
Joined: 29 Jan 2008 Posts: 1214 Location: Birmingham, United Kingdom Thanked: 123 times
Posted: Tue Mar 23, 2010 2:20 pm |
Always prefer the largest pipe to rad connections you can get ie15mm.
Unless it is particularly intrusive i think you have made the right decision |
| Back to top |
seco services
Joined: 03 Dec 2007 Posts: 15466 Location: Essex, United Kingdom Thanked: 1215 times
i prefer 15mm over 10mm. |
| Back to top |
LeeC
Joined: 19 Feb 2006 Posts: 10906 Location: Nottingham, United Kingdom Thanked: 2240 times
Posted: Tue Mar 23, 2010 3:14 pm |
22mm to 10mm for me |
| Back to top |
mickroyds
Posted: Tue Mar 23, 2010 3:23 pm |
s**'s law someone would tip the scales, but that was the nature of the question
Has this been asked before ?
Thanks up to date.
Mick. |
| Back to top |
sambotc
Joined: 10 Apr 2007 Posts: 579 Location: United Kingdom Thanked: 14 times
| Back to top |
dextrous
Joined: 14 Mar 2009 Posts: 6321 Location: Manchester, United Kingdom Thanked: 194 times
| Back to top |
electronicsuk
Joined: 07 May 2007 Posts: 3303 Location: Lincolnshire, United Kingdom Thanked: 273 times
Posted: Tue Mar 23, 2010 7:10 pm |
Always 15mm to the rads. Plus, 15mm is readily available with chrome plating, which gives a professional touch when the tails only have a short run out of the floor or wall into the valves. |
| Back to top |
LeeC
Posted: Tue Mar 23, 2010 7:15 pm |
| electronicsuk wrote: | | Always 15mm to the rads. Plus, 15mm is readily available with chrome plating, which gives a professional touch when the tails only have a short run out of the floor or wall into the valves. |
i cant think of anytjing more DIY than chrome pipe into rad valves.(chrome towel rads are the exception)  |
| Back to top |
sambotc
| Back to top |
gas112
Joined: 27 Oct 2009 Posts: 4563 Location: Unknown or unspecified country Thanked: 746 times
Posted: Tue Mar 23, 2010 7:18 pm |
15mm always . looks far better and neater |
| Back to top |
dextrous
Posted: Tue Mar 23, 2010 7:19 pm |
| lcgs wrote: | | electronicsuk wrote: | | Always 15mm to the rads. Plus, 15mm is readily available with chrome plating, which gives a professional touch when the tails only have a short run out of the floor or wall into the valves. |
i cant think of anytjing more DIY than chrome pipe into rad valves.(chrome towel rads are the exception)  | Exactly. Especially when there are so many braided flexis on the market |
| Back to top |
mickroyds
Posted: Tue Mar 23, 2010 7:23 pm |
You have me confused ??
But I agree, Harry Carpenter, much admired and respected a reporting sporting legend.
Mick. |
| Back to top |
electronicsuk
| Back to top |
dextrous
Posted: Tue Mar 23, 2010 7:25 pm |
Only larking about. 22 to 15 is good |
| Back to top |
