hummingbird
Joined: 07 Apr 2010 Posts: 32 Location: United Kingdom
Posted: Sun May 23, 2010 10:10 pm |
Indesit WIL133 washing machine
It fills up but then after about 15 seconds, it empties. Then it does this again and again, until I switch it off at the wall. It won't switch off at the machine. Several lights flash - the door light, easy iron and extra rinse.
Thank you for any advice. |
rocks1
Joined: 30 Apr 2008 Posts: 5360 Location: Turkey Thanked: 876 times
Posted: Sun May 23, 2010 10:18 pm |
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board |
| Back to top |
hummingbird
Posted: Mon May 24, 2010 5:27 pm |
Thank you very much for this list. It's lights 3&4 - am I right in thinking that NTC is the brand name of the thermostat? If so, then I think we know how to change that.
Great, thanks! |
Leccy758
Joined: 18 May 2008 Posts: 1256 Location: Cornwall, United Kingdom Thanked: 193 times
Posted: Mon May 24, 2010 5:52 pm |
NTC stands for Negative Temperature Coefficient
PTC stands for Positive Temperature Coefficient
One increases resistance when heated the other decreases resistance when heated.
They are both used as temperature sensors though. They need to be matched up to the programmer so it can measure the correct temperature. |
| Back to top |
hummingbird
Posted: Wed May 26, 2010 12:18 pm |
| Leccy758 wrote: |
Thank you. We've got the old sensor out and found a place locally which sells replacements so we'll try that. |
Twotrees408
Joined: 11 Jun 2011 Posts: 1 Location: United Kingdom
Posted: Sat Jun 11, 2011 8:23 am |
Keep turning off then starts up again |
