I have an Advantage ZX6 panel with one PIR and two door contacts. It is approx 16yrs old and whilst is ok, I would like to update the panel to something more modern such as Honeywell Accenta GEN 4 panel as per their website. This is mainly so I can add additional PIR and contacts and have a PA option(s).
However, the big question is, can this be done easily using the same wiring and PIR's / Contact sand most importantly the same outdoor bell box (I don't have ladders!). Is this likely to be an issue if I do this and is the Honeywell range a good panel?, Ideally I would just like to change the panel using the same wiring and sensors.
Also, the existing panel is wired direct from the CU (0.5m of 1mm cable) via the fuse for the upper light circuit - is this ok or should it have a further 3A FCU installed?
Any advice greatfully received.
