DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
ford fiesta 1.4 tdci vibration
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance
Search this topic :: View previous topic :: View next topic
Author Message
mick63
from United Kingdom
PostPosted: Sat Apr 16, 2011 1:34 pm Reply with quote
hi i`ve got a 2003 ford fiesta 1.4 tdci its done 56,000 miles & when the car is sat idleing the whole car shakes & vibrates . Any thoughtsof what is causing it ? Many thanks for any help Mick
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
Burnerman
from United Kingdom
Thanked: 2568 times
PostPosted: Sat Apr 16, 2011 3:43 pm Reply with quote
Do you think the engine could be only firing on 3 cylinders, maybe? I've had a couple of these with injector faults, and diesel leaks.
Back to top
The following user says thank you to Burnerman for this useful post:
mick63 (17 Apr 2011)
 Alert Moderators
Whitworth
from United Kingdom
Thanked: 15 times
PostPosted: Sat Apr 16, 2011 3:44 pm Reply with quote
Could be a worn engine mount rubber. With engine cold give the engine a good shake and listen for any metal to metal contact.
Back to top
The following user says thank you to Whitworth for this useful post:
 Alert Moderators
mick63
from United Kingdom
PostPosted: Sun Apr 17, 2011 8:19 am Reply with quote
. Thanks that sounds right . When the car had its M.O.T. just recently tha guy said it sounded like it was only running on 3 cylinders & he said it had a slight fuel leak! Any suggestions to what i should do to cure it please ? Many thanks for the help as well .
Back to top
 Alert Moderators
Burnerman
from United Kingdom
Thanked: 2568 times
PostPosted: Sun Apr 17, 2011 8:57 am Reply with quote
Hello Mick
The injectors on this car are at the back of the engine - not so bad to get to, but a lot of dismantling is needed if you want to try yourself.
The injectors are held in by one nut and a clamp down plate - with these removed the injector pulls out to reveal its copper sealing washer which must be renewed, together with a plastic sleeve that keeps the injector centralised in the hole.
In theory, the copper washer keeps things fuel tight but on rare occasions this doesn't work and the cylinder head has to be refaced in that contact area - not what you want!
Each injector is connected to the next one by rubber leak off pipes - these take uninjected fuel directly back to the tank. Its worth looking at these for leaks too, before you get stuck in. Measuring the amount of diesel leak off by each injector is probably the only way of analysing injector performance on common rail systems, and you are in to specialist territory here.
Maybe this info will help you decide which way you want to go.
Back to top
 Alert Moderators
mick63
from United Kingdom
PostPosted: Sun Apr 17, 2011 3:47 pm Reply with quote
Burnerman wrote:
Hello Mick
thats great John many many thanks for your help & time hopefully it won`t be too expensive to rectify many thanks again Mick
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Car Repairs / Maintenance All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Ford Focus Zetec, Vibration problem 6 6420 Wed Feb 15, 2006 7:47 pm
Vibration on Citroen C15 van 2 520 Fri May 29, 2009 11:51 am
Vibration through steering wheel ?? 10 1580 Thu Oct 19, 2006 4:26 pm
vibration in nissan micra 5 160 Fri Sep 23, 2011 7:21 am
Slight Vibration/Murmer 7 540 Tue Dec 16, 2008 2:04 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
