DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
The DOGS in silicone sealent CT 1
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials
Search this topic :: View previous topic :: View next topic
Author Message
gingerbear
from United Kingdom
Thanked: 2 times
PostPosted: Fri Apr 22, 2011 6:09 pm Reply with quote
This silicone works even when water is present, and it apparently works under water. If anyone aint tried this then your missing out !
My merchant seen the rep fix a plastic cup full of water with a split in it and
I used some the other day on a job 5 guys from my company had been to and it cured the problem no messing !
Available in clear,white and grey and it sticks anthing to anything i hear !
I rate this highly and someone shud of come up with this years ago
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
muggles
from United Kingdom
Thanked: 517 times
PostPosted: Sat Apr 23, 2011 10:25 pm Reply with quote
Been around for years, similar stuff to Sticks Like Sh¡t and Serious Stuff, but in a choice of colours (I think you can get black and beige as well). Good stuff but expensive compared to standard bathroom silicone, which is all you really need most of the time
Back to top
 Alert Moderators
htgeng
from United Kingdom
Thanked: 94 times
PostPosted: Sun Apr 24, 2011 3:36 pm Reply with quote
gingerbear wrote:
You will never want to use regular silicone sealant once you've started using CT1. Warning to cheapskates though, its around £8-9 a tube!
Another thing you should try is the CT1 solvent spray. Then when you use the sealant spray solvent onto it. Then you can shape or neaten up the sealant without affecting the adhesion. They also recommend you prep any surfaces to remove dirt using the spray. Any excess on your fingers wipes clean off with the solvent or cleaning wipes.
When the sealant dries it has a hard rubber appearance and isn't as stretchy as your usual silicone.
Back to top
 Alert Moderators
gingerbear
from United Kingdom
Thanked: 2 times
PostPosted: Sun Apr 24, 2011 6:33 pm Reply with quote
compared to standard bathroom silicone, which is all you really need most of the time[/quote] Forget your standard sealent now ! defo would'nt touch the stuff as after a while most of them end up going mouldy and looks rank ! as for sticks like s**t! used that but thought it was more of a builders product for things like sticking skirting boards and other bodge like jobs ?
Back to top
 Alert Moderators
htgeng
from United Kingdom
Thanked: 94 times
PostPosted: Sun Apr 24, 2011 7:50 pm Reply with quote
If you want to try a couple of other products in mastic tubes then;
5 minute Polyurethane Wood Adhesive Gel (toolstation )78519. This stuff replaces your standard waterproof wood glue. You wet both wood surfaces so they are damp. Apply minimal glue and spread it out. Clamp the wood if possible and it will be set in 5 minutes. The glue foams slightly so will fill small gaps. Don't get any on clothes, hands or other surfaces!
Another sold by Screwfix is 20229. Ceresit PL500 Instant Grab. Works better than most of the other 'grab' adhesives. After about 24 hours it sets solid hard so you can paint over it.
Back to top
The following user says thank you to htgeng for this useful post:
gingerbear (25 Apr 2011)
 Alert Moderators
iaith
from United Kingdom
Thanked: 21 times
PostPosted: Tue Apr 26, 2011 12:32 pm Reply with quote
Hay! Gingerbear. are you sure you don't work for CT1? lol.
I know what you mean tho' it is a great product, I tend to use stixall,or workx, now as they are much cheaper and seem to do the same job.
Back to top
The following user says thank you to iaith for this useful post:
gingerbear (26 Apr 2011)
 Alert Moderators
htgeng
from United Kingdom
Thanked: 94 times
PostPosted: Thu Apr 28, 2011 12:04 am Reply with quote
iaith wrote:
Hay! Gingerbear. are you sure you don't work for CT1? lol..
I sure wish *I* did to get freebies. Btw, why did they give it such a dumbass name. I mean what marketing Einstein came up with 'CT1'. If I suggest a better name can I have a pallet load of the stuff? icon_biggrin.gif Come on guys some of the best products on the market have been renamed. You should really sell it to the USA as that market is huge and would earn you 100's of millions.
Used the 'Clear CT1' yesterday to seal grp roofing sheets that sit almost horizontal. Was getting rain wicking back into the overlaps. CT1 has sealed them beautifully, 100% and its completely see through. I must take some pics of the job and post them up. Again if you've not used the can of solvent its a must buy. When you spray a little solvent on the fresh sealant it almost comes alive and you can shape and sculp the stuff just as if you were shaping fresh putty.
Back to top
 Alert Moderators
opps
from United Kingdom
Thanked: 179 times
PostPosted: Wed May 11, 2011 6:57 am Reply with quote
Thanks for the recommendation- how does this stuff differ from the likes of SikaFlex (which is dificult to smooth out).
Back to top
 Alert Moderators
terence7556
from United Kingdom
Thanked: 124 times
PostPosted: Wed May 11, 2011 4:37 pm Reply with quote
i have a hairline crack in an aav pot, on a turbomax 242, the pot is directly mounted behind the pump.cheapest price for a pump is £100 plus vat, would this be worth a try as its only a weep
Back to top
 Alert Moderators
foxhole
from United Kingdom
Thanked: 509 times
PostPosted: Sat May 14, 2011 9:39 pm Reply with quote
Just tried CT1 for the first time and would not recommend for a smooth finish, drags and is like trying to smooth contact adhesive.Requires a lot of pressure to extrude from gun.
Also tried the solvent and so far not found anything it will remove, tried it on some old adhesive staining on pvc and would not touch the marks, also tried it to remove double sided foam adhesive and no luck , would not even remove CT1 which I would have thought it was created for?
Back to top
 Alert Moderators
htgeng
from United Kingdom
Thanked: 94 times
PostPosted: Sun May 15, 2011 12:47 am Reply with quote
Sounds like a wind up to me. Its consistency is similar to regular silicone so how can it be any harder to extrude? When you've applied a bead of it, you can spray the solvent on it to allow it to smooth out.
Back to top
 Alert Moderators
foxhole
from United Kingdom
Thanked: 509 times
PostPosted: Tue May 17, 2011 4:34 pm Reply with quote
I tried the solvent had no effect on the ct1.I found it thicker than silicon and as it contains adhesive very sticky and therefor difficult to smooth.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tools and Materials All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
What is the best sealent for a glass gas hob? 2 201 Mon Nov 15, 2010 10:02 pm
Colorfill sealant or silicone sealant on joints 6 500 Fri Apr 08, 2011 1:32 pm
High temp silicone 4 160 Sat Apr 06, 2013 9:02 pm
Anti mould silicone 7 920 Tue Mar 15, 2011 7:30 pm
translucent vs clear silicone sealant? 7 1600 Wed Nov 17, 2010 5:29 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
