Alarm experts help !
7 Jan 2007
Do any of you lads know of a way of using a remote to turn a siren on fitted to a van (shock and scare tactic ) and also possibly wireless cctc cameras in a van to dowload to a nearby harddrive system ? Thanks.
Had no problems so far but as the double dip bites the scroats will come creeping out !
1, any decent alarm has a "panic " facility. So would do as required.
2, A car is a "FARADAY" cage. So transmitting out is a bit of hit and miss.
Recently quoted for it but was thankfull it was refused.
There are many small DVR`s nowdays made for cars/vans/coaches.
Trick is hiding the cameras inside.
Small "board" cams can be hidden away, just takes a bit of imiganation.
Also you have to think of battery life, if the van isnt moved for a while.
Observation from the outside is better, as they "case" the van. Then you have more chance of getting a better image of the bar stewards.
