DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
How tight
This topic originated from the How to page called Fitting new taps
Click here to return to the page called Fitting new taps.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
Search this topic :: View previous topic :: View next topic
Author Message
Guest
PostPosted: Thu Sep 12, 2002 8:37 am Reply with quote
When connecting the tails to the tap how tight should they be done up, the ones I am about to fit have o-rings so if I over tighten them they are likely to become damaged. Is there a rule of thumb to use in this situation?
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
Guest
PostPosted: Thu Sep 12, 2002 9:48 am Reply with quote
With o-rings there is no need for a lot of tightening. Hand tight will often be leakfree, but it is usual to give them a gentle 'nip' with a spanner to make sure they don't work loose.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Plastic fitting on steel pipe - just a fraction too tight. 9 220 Wed Jan 29, 2014 11:13 am
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy. Copyright © 2000-2014 DIYnot Limited.
