DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
wbp ply bathroom floor???
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling
Search this topic :: View previous topic :: View next topic
Author Message
paul78
from United Kingdom
Thanked: 24 times
PostPosted: Sun Feb 13, 2011 10:26 pm Reply with quote
just curious what you pros do with prepping the bathroom floor....
wbp 18mm at least... even if it raises the floor higher than next room?
same height wbp in mm to match the next floor?
im thinking strength is more important than the two floors being same height, so sacrafices have to be made???
also do you prime the wbp or only if the (flexible) adhesive bag advices it.
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
vv2806
from United Kingdom
Thanked: 39 times
PostPosted: Sun Feb 13, 2011 11:40 pm Reply with quote
I am not a pro, just tiled the whole bathroom. The floorboards were rotten but even if they were not, I would remove them anyway. Then made the new floor from WBP. In this way the difference in the levels is not so big. Finished it with a threshold from B&Q, they and the other sheds sell thresholds suitable for different levels and different floor finishes - tiles and carpet in my case.
Back to top
 Alert Moderators
jefoss
from United Kingdom
Thanked: 19 times
PostPosted: Mon Feb 14, 2011 12:18 am Reply with quote
when you say 18mm are you talking about total replacement of the floorboards or overboarding?
total replacement should be 25mm and overboarding is 15mm minimum (imo)
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1467 times
PostPosted: Mon Feb 14, 2011 1:05 am Reply with quote
I'd go for pulling up the old floor and re-doing it in WBP. I recently did a large room like that, with noggins under the short edges. It is firmer, stronger and more rigid, and i think quieter too. If you can carry an 8x4 sheet into teh room, you should have very few joins (which are where most flexing is found)
I used 18mm but this was not to be tiled, maybe the 25mm is even more rigid, I don't know.
Back to top
 Alert Moderators
lancenotalot
from United Kingdom
Thanked: 43 times
PostPosted: Mon Feb 14, 2011 10:19 am Reply with quote
12mm ply to overboard or 6mm backers
Back to top
 Alert Moderators
paul78
from United Kingdom
Thanked: 24 times
PostPosted: Mon Feb 14, 2011 10:53 am Reply with quote
any recommendations on the addy/grout etc i think bal flexible for both just for the added peace of mind, also do i leave an expansion gap around the perimeter of the floor for the ply
Back to top
 Alert Moderators
jctilingservices
from United Kingdom
Thanked: 138 times
PostPosted: Mon Feb 14, 2011 3:58 pm Reply with quote
6mm tile backerboard or at the very LEAST 12mm WBP ply, if you lift your boards to replace with ply (not overboarding) you will have to seal the underside and edges before fitting, also dont nail the ply, screw it at 150mm centres
Back to top
 Alert Moderators
paul78
from United Kingdom
Thanked: 24 times
PostPosted: Mon Feb 14, 2011 5:56 pm Reply with quote
thanks for the replies guys, be lost without this forum.
Back to top
 Alert Moderators
Tully
from United Kingdom
PostPosted: Thu Feb 23, 2012 11:13 am Reply with quote
Hi guys i have a sturdy floor but its made of OSB 18mm thick is that okay to tile onto if say I prepped it with a covering of primer/pva /
Back to top
 Alert Moderators
prceramics
from United Kingdom
Thanked: 7 times
PostPosted: Thu Feb 23, 2012 12:07 pm Reply with quote
chipboard ?
Back to top
 Alert Moderators
Tully
from United Kingdom
PostPosted: Thu Feb 23, 2012 1:47 pm Reply with quote
Yes its an external chipboard is that no good ?
Back to top
 Alert Moderators
prceramics
from United Kingdom
Thanked: 7 times
PostPosted: Thu Feb 23, 2012 7:14 pm Reply with quote
i would put a cement backerboard down first mate
Back to top
 Alert Moderators
tictic
from United Kingdom
Thanked: 172 times
PostPosted: Thu Feb 23, 2012 8:55 pm Reply with quote
Don't put anything ontop off the osb....
Lift and replace with wbp ply...seal underside and edges prior to fixing ply down with acrylic primer...
Osb is like weetabix....you will need fix cement boards down ontop off it with a SPF....thus turning it into weetabix....
Back to top
The following user says thank you to tictic for this useful post:
Tully (24 Feb 2012)
 Alert Moderators
Tully
from United Kingdom
PostPosted: Sun Feb 26, 2012 6:17 pm Reply with quote
Thanks Guys, I am widowed female the builder that fitted it said it was marine ply athough it looked like chipboard to me no no he said thats a special looking ply. I only worked it out when I saw one of the bills and some of it got wet yes just like weetabix your spot on anyway...his coming around tomorrow to chat about it.
I try and do most things myself this was too physical for me. Your help is always great thanks again not sure what I will say to him but chin up.
Back to top
 Alert Moderators
Tully
from United Kingdom
PostPosted: Sun Mar 04, 2012 6:07 pm Reply with quote
Hi Guys well contractor not interested in changing it was very nasty but what the heck moving on been into local merchants they have the following which they tell me is a boil plywood ? if I buy and cut in small runs with my jig I should be able to fit it by myself and get rid of the OSD been into the yard and the stamp on the ply is 2x EN636 2 EN314 2 Ext E2 any good ? to replace OSB floors in upstair bathroom so that I might tile it do I need to varnish it/ seal it in some way basically is this fit for purpose? CE 0407CPD 436 2x EN636 2 EN314 2 Ext E2
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Tiling All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
tiling bathroom floor 3 80 Sun Jan 16, 2011 10:12 am
Bathroom floor tiles, need for plywood under layer? 8 6340 Fri Jan 21, 2011 7:46 pm
Similar sized bathroom wall and floor tiles 4 740 Sun May 02, 2010 6:56 am
25mm plywood floor or hardibacker overboarding in bathroom? 9 7500 Fri Jan 07, 2011 8:56 pm
Two quick questions regarding tyling bathroom floor 3 460 Tue Mar 30, 2010 3:09 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
