Boiler is showing a central heating demand when thermostat is turned down, but the burner was off. Any clues as to why this happens appreciated.
Are any lights showing a fault display at all?
Yes, room stat.By thermostat I presume you mean the room stat?not the boiler stat? if the programmer is calling for heating then regardless of what the room stat setting is the boiler will be waiting for a call from room stat so it could easily be showing that heating is on but it won't fire up until room stat says it's cold enough to fire up.
