How do you fix a slotted fence panel at a right angle?
28 Dec 2008
Southampton
Hi all,
We're buying new fence panels and slotted concrete fence posts to make a new fence around our 3m x 6m x 3m rectangle patio enclosure.
On the Wickes website (UK) there is only one slotted concrete post. Is it assumed that you do not need a right-angle slotted post for corners? If so, what is the standard way of fixing two fence panels together at a right angle with a standard slotted fence post? I've noticed two small holes in the post, do you bolt one fence panel to the post at a right angle, whilst the other panel goes into the slot as normal?
The concrete slotted post available is:
http://www.wickes.co.uk/Wickes-Slotted-Concrete-Fence-Post-100mmx60mmx2-4m/p/540063
Many thanks!
I couldn't find one of those corner posts up here either....I ended up concreting in two posts, one turned 90 deg to the other.
Not the easiest way to sort the job!
John :)
