I have an open vented Y-Plan CH system, now 15 years old. The house is a mid-terrace two bed 2 floor house
It's been running OK apart from issues with the Myson 3 port valve, sometimes the actuator doesn't turn unless persuaded with a punch! I have noticed the spindle on the valve body was rather stiff and wasn't sure if a new valve would be so stiff. After 15 years I am on the fourth actuator and when I discovered the valve is stiffer than a new Myson 3 port valve, I decided it was time to replace it.
The Myson pump does run quiet and there are no issues but I thought "What the heck"... so I'll be replacing this with a Grundfos Alpha 2L, more electrically efficient and quieter, how quiet in comparison to the working Myson will be interesting to hear.
The Potterton Suprima 30 boiler is serviced once a year by a local gas engineer, the PCB was replaced years ago (a well known fault).
The schedule is to undertake this overhaul on 2nd May. In preparation and 3 weeks ago I drained the system, cleaned out the FE tank which had a bit of rusty sediment (that I scooped out and mopped up with an old cotton t-shirt - I won't be wearing that again). Then with the Sentinel X400 system cleaner to hand and beginning a refill I noted the ballcock was rather manky looking and bunged up with calcium deposits and struggled to work at all, so I sped to Screwfix for a replacement and duly fitted.
