How Does My Open Vented Gravity fed System Work
21 Aug 2014
Derbyshire
Hi i am a plumbing enthusiast (not a plumber) i have a genuine interest in how things work mainly in case things break iv a good genuine knowledge of how to or what needs to be repaired. iv recently moved propertys and the new house has what i believe to be a open vented gravity fed back boiler heating system (very old). When i look in the cupboard to the side of the boiler in the kitchen there are 5 pipes. 1 is i believe the gas pipe to the boiler, 2 will be the hot water flow and returns and 2 will be the ch flow and return. there is a grunfos pump on 1 of the pipes which if im right in thinking will be the ch flow pipe.
Am i right in thinking that the hot water flow and return to the boiler simply goes upto the cylinder and back down to the boiler heating the water in the cylinder.
And the ch flow and return is pumped by the grunfos pump around the house and back to the boiler??? ????????
In a word - yes - exactly as you said. Back boiler relies on heated water rising to heat the cylinder then falling back to the boiler as it cools by virtue of losing heat to the cylinder - thermo-syphon principle.
ok so the hot water doesnt need to be umped? also how come when the hot water comes on does the ch flow pipe become warm ie making a select few of the rediators slightly warm ???????????
Basic back boiler setup - no pump used for the hot water circuit. Not the most efficient way by today's standards but the back boilers are not particularly controllable so not really any way to control a pump, if one were to be fitted.
As for the central heating getting warm, this is possible due to the same principle as for the hot water circuit. Heated water rises so may induce some circulation in the central heating too.
ok thats logical, so the ch flow and return dont go to the cylinder or have anything to do with it, they simple go from the back boiler and back to the back boiler.
Quite so. Usually piped from opposing sides of the back boiler to reduce the possibility of inducing circulation in the other circuit. The setup is about as basic as you can get in terms of heating systems these days.
ok so what is the difference from a direct and indirect system as i believe i have indirect system
A direct system would be your cylinder being heated by an immersion heater, indirect by your boiler
my cylinder has a immersion in the top of it tho even tho it says indirect on the fromt of the cylinder??
Your cylinder is Indirect, heated by the boiler but has an immersion as an emergency back up.
Direct would just use immersions
ow right so the immersion is a back up got you brilliant now im getting somewhere. i cant work out if i should rip it out and put a combi in instead. thoughts ??????
If you only have one bathroom, only use one hot water outlet at a time, don't mind having no hot water at all when the boiler breaks and want your bath to fill much more slowly than it does now, then by all means get a combination boiler.
Otherwise, keep what you have and when it breaks beyond repair get a proper replacement boiler.
Direct has immersion heater
Indirect has a coil and immersion heater
Not quite; we had a copper cylinder with no immersion and no c/h coil - only way to get hot water was light a fire or boil a kettle :eek: well it was a 1950 council house ;)
Probably missing the Non return valve or anti-gravity valve or stuck open if one is fitted.
Daniel
