Remeha Avanta Plus 28c leak...
22 Nov 2014
Yorkshire
I've had the Condensing Boiler for over 4 years and has been very reliable. It has just been serviced by the installing engineer so all should be ok right? It has just started to drip a little out of the pipe in the picture, it is a constant drip but not fast. I've tried to get in touch with the Engineer who fitted it but I think he may be on holiday. Is there any easy fix for this?
Any help/advice would be greatly appreciated!
Also no fault codes displayed!
Try tightening up the square bit on the end, otherwise a new washer will be required inside.
The leak is coming not from the end piece but the downward pointing coupling. Should the boiler seep occasionally when the heating is on as it is a condenser?
As above tighten the bit on the end. That should stop the drip.
