Hello
I have recently changed my 3 port valve because I was not getting any hot water via central heating, I had to use immersion only. I assumed it was the valve stuck in heating position only as the manual lever on the valve was floppy and not doing anything. it was quite old valve and hasn't been replaced for years. so put new valve on tested heating which was fine but pump did not start up when I changed it to water only. the Honeywell controller light came on but that's all. Have I changed this for nothing and is it possibly a fault wiTh my boiler ( glowworm micron )
