Jimbo320, hi
OK Still off post, sorry about this but these comments may~? be relevant?
I have been asked to investigate dozens of insurance claims where water is entering the under building below floors.
If the cause is Ground water, the majority of insurers will walk away, but?
If you can prove that the water entering the property can be proved to contain any of the following then the insurer may assist in getting a remedy?
There are Companies who can perform Chemical / almost forensic tests on the water and tell if it contains, Chlorine? Soap? Faecal material?
If the water contains Chlorine and a couple of other components then the water MAY be coming from a fractured water main?
If the water contains Soap there is a high probability that the water is escaping from a Foul Drain.
As for faecal material that indicates a fractured failed Foul Sewer
As can be imagined, if you can prove what is in the water then you can get the relevant Authority to sort the escapes of water, or Sewage?
OK the investigations are not cheap to undertake but if you can prove the source then the utility provider / supplier can be held up to undertake the requisite repair.
Ken
Ken
