Looking for an Expert
13 May 2015
Yorkshire
Hi All
This is my first post!
We're looking for a professional who can help us with a Vaillant Boiler that's rigged up to a weather compensator and a pressurised cylinder that takes in a supply from a set of solar panels.
Everything is working!
All we want is for someone to come in and check that everything is working as efficiently as possible and the weather compensator is configured correctly.
We're at the northern edge of Bradford, near Wilsden.
Look forward to hearing from anyone who can help.
Kind regards
I'll post a link to the closed section, there's some Vaillant specialists in there.
What's up with it? Who fitted it? Can't you get them back to sort it out if it's not up to expectations?
Pal, don't bother here. They're all suggesting so far it's a **** DIY install or your after someone to sign crap work off.
Not sure what ever happened to people actually wanting proper tradesmen to do proper work and make things happen like you want.
I hate doing this, but stuff giving your money to and independent, ring Vaillant, they'll send an engineer to service and setup your kit, then all the independents can moan about how manufacturers try and steal their customers!
Crying shame people assume everything is a fiddle!
Or maybe it is. ;)
But if the Vaillant was installed by a competent gas registered engineer then something is wrong if the Owner does not trust him to come back and service and check the setup.
I hope he had the installation registered for the warranty and remembers that the boiler needs to have a documented service every year to maintain the warranty.
It does sound as if it was fitted by a builder or someone else whom he does not trust to have done it properly.
Sounds like a job for Alec !
Original installer may have died, retired, emigrated, took a job, gone bust.
FFS, do you post because you feel the need to see your name appear.
Like I've said, fook em, ring vaillant, let em keep crying in the hidden section that vaillant want their business!
WOW - quite a lot of assumptions!
The system is working absolutely fine, it was fitted by a registered Gas Engineer! Certificate to prove!
My question was a simple one I thought, maybe I mislead you guys (and girls). I just wanted to make sure everything was still running efficiently! Don't know if the Weather Compensator is working as it should be.
Was hoping that someone might just point me to a competent person that would have a glance over it (paid of course!)
For those that are jumping to irrational conclusions it is quite likely that when someone moves into a house they have no idea what went on before. I'm not asking for anyone to "fix" anything, because nothing is broken! The system is working absolutely fine, I just wanted to be confident that it's all setup fine.
In any case, I'll contact a Vaillant - LeeC thanks for your rationality!
(Don't Assume as it makes an Ass of You.....not me)
Feel for you, there's enough competent people on here but are too scared of their own shadow to think someone might just be genuine.
Sorry, tried but all they wanted to do was concentrate on it being a dodgy customer/job.
