Re-lay Paving slabs, heavy 3ft x 2ft x 2inch. 80 of them.
9 Apr 2012
I have a patio just outside my back door that consists of 80
3ft x 2ft x 2inch grey paving slabs.
These old 3ft x 2ft x 2inch grey paving slabs are no longer available.
A number were cracked and have been lifted and replaced with the modern version which is a 900mm x 600mm grey paving slab.
Almost the same size though slightly smaller.
The patio goes up and down and all over the place.
When these were laid in 1972 little attention was paid to whether the patio was flat.
It is not, and I'm about to begin the hefty job of re-laying it / flattening it out.
Questions :
1. These paving slabs are REALLY heavy. What's the best method for handling them.
2. What's the best way to get a large area really flat. I've been using a long wood 'spreading' batten with a straight edge and builders sand. Ideas ?
3. What is the best material to put between the gaps to stop weeds growing up and through.
All tips and ideas greatly appreciated.
Thank you :)
Paving expert is the best resource for all this kind of stuff, including stuff on lifting:
http://www.pavingexpert.com/layflag1.htm
On a personal note, I shifted about 10 of these slabs about 30 meters recently in preparation for some building work. I'm in pretty good shape I suppose and I couldn't believe how hard it was. I wouldn't dream of laying them on my own. One of the builders who came to do the work also struggled with one. (Though to be fair, his rather younger labourer did manage a bit better.) I would definitely look at getting hold of one of the lifting aids mentioned on the PE site if I was you.
laying them on building sand is wrong. If you dont want to lay them on a mortar bed then you need to use a very course grit sand.
They are brutal to work with. reclaimation places will keep them if you want to try and get matching ones.
A probst slab lifter makes it much safer and more manageble.
