Hello,
I took a liking to an american faucet when on hols recently, so I bought one. I have 2 questions that I'm hoping someone can answer
1. The tap uses 1/2" IPS connectors to connect to hot and cold supply, are these fittings available in the uk/ireland? Looks like a threaded male connector, so will need the female equivilent.
2. As this is a kitchen tap, will it work ok with uk/ire pressure? think the cold is direct from main and hot from overhead tank pressure.
Any comments/suggestions are most welcome
and before I get a slagging for buying an american tap, it was well cheap (about 1/4 the price of similiar ones over here) so couldn't resist!!
if you want to see more specs for it see the below link.
http://www.moen.com/shared/pdf/87325Csp.pdf
Thanks in advance!
Thanks in advance!
