Fluctuating Water Temperature - Combi Boiler
9 Aug 2006
London
We bought a 3 bed, 2 bathroom + a guest toilet flat which has a Winchester 24i boiler (unknown age). When we run the water in the shower or kitchen sink, the water temperature through the mixer fluctuates considerable, even when there is just one of us home. Does anyone know if this is a boiler fault or a plumbing issue. In winter the one bathroom shower (closer to the boiler) never gets hot enough, but the en-suite (further from the boiler) does get hot enough which does not seem to make sense to me. Both will then fluctuate in temperature. Any help would be much appreciated.
hi,
a common cause for this is also the gas valve modulator min/max settings not being right; the answer is to get a local corgi engineer to set the gas valve up to the pressures in the handbook, both the maximum and the minimum settings will need adjusting
Can anyone tell me more about a Winchester 24i boiler?
Clearly Fitz and Theaky seem to know about them!
Alfredo said:
I think the Winchester is the 15/50 pump action model :LOL: :LOL:
Alfredo
maybe we should turn up on the doorstep in a cowboy outfit... seems to be the thing for john prescott.
perhaps it'll catch on
graham
