I need 3 rads & hot water for tiny 1 bedroom house can you please tell me how much this should cost please
____________________________________
lynda, moderator
I saw a 2003 heatline boiler removed two months ago. There was nothing wrong with it apart from the dirt in the system which has had to be power flushed after the new boiler was fitted.
thanks I was going to buy the full lot boiler rads n pipes n fittings for £600 from local supplier there is no old system to remove i just need to know how much it would be to get it fitted it is onley 3 rads n hot water there are holes for the pipes from when the old system was in
Hiya, if your suppliying parts, labour is going to be a little more than usual but if the job is as simple as you say, with a quick power flush and combi exchange with yourself purchasing materials then your looking around £700. Can a condesing boiler go in situe no probs or do you look like getting disspensation?
it is very difficult to give a rough estimate without looking at the job. Every house is different some can be dobe in the half the amout of time as others.
