DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
Olive removing tool
Goto page 1, 2, 3, 4  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Search this topic :: View previous topic :: View next topic
Author Message
ptarling
from United Kingdom
PostPosted: Thu Sep 28, 2006 9:55 am Reply with quote
Hello,
If anyone can give me some advice - would appreciate it...
Thinking of buying an olive removing tool. As far as I can see there is a cheaper model that will remove both 15/22mm olives (the tool screws on to the existing compression locking nut and you pull the olive off) or there is a more expensive tool that splits the olive (but 2 seperate tools required to do both 15 & 22mm).
Will the cheaper one suffice or are they unreliable..???
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
JPC
from United Kingdom
Thanked: 19 times
PostPosted: Thu Sep 28, 2006 4:12 pm Reply with quote
i bought a 15mm mor expensive type.
it lasted about a month. the cutting teeth are now blunt and it compresses the olive (and pipe) and in so doing causes more work !
i now have gone back to me hack saw
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 945 times
PostPosted: Fri Sep 29, 2006 12:51 am Reply with quote
I've got them (all!).
The screwy one which does both sizes (unless the threads's the older finer prestex type) is the better bet.
Either that or cut yourself a set of very short lengths of copper pipe, and put them in a compression fitting, starting with the shortest, and do the nut up. As you do so it'll slide the olive along the pipe. When tight, undo the fitting and put a longer bit of pipe in, and repeat. See?
Back to top
 Alert Moderators
croydoncorgi
from United Kingdom
Thanked: 332 times
PostPosted: Fri Sep 29, 2006 7:13 am Reply with quote
The splitting-type tool does for me, for 15mm. Larger sizes = less frequently needed and easier to work on = carry on using hacksaw.
The other problem is the quality of the plumbing BEFORE you came on the scene! If a compression joint has been over-tightened so that the olive has dug in and 'necked' the tube, there's no point removing it in most cases! You won't get a leaktight joint on the tube a second time anyway.
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 945 times
PostPosted: Fri Sep 29, 2006 8:44 am Reply with quote
The plug centre of the screw-on type, goes some way to reshaping the pipe.
SOmeone ought to make a tap-in bar of the right size to do the job. 13.6mm!
Back to top
 Alert Moderators
ptarling
from United Kingdom
PostPosted: Mon Oct 02, 2006 9:39 am Reply with quote
This sounds like a good plan!!!! Thanks for advice
Back to top
 Alert Moderators
ptarling
from United Kingdom
PostPosted: Mon Oct 02, 2006 9:42 am Reply with quote
Thanks for advice!!
Back to top
 Alert Moderators
ben28
from United Kingdom
PostPosted: Tue Oct 03, 2006 4:22 pm Reply with quote
I have monument 15mm/22mm removal tool, it is very usefull and avoids the problem of cutting the pipe and the olive when using a hacksaw. Occasionaly the effort required to turn the handle can be difficult in tight spaces. On the whole its a usefull bit of kit though.
Back to top
 Alert Moderators
nigelad
from United Kingdom
PostPosted: Tue Nov 28, 2006 8:23 pm Reply with quote
Didn't know you get tools to deal with olives until I saw this thread!
I replaced 9 rad valves with TRVs recently, and removing the old olives was the hardest part of the job!
I was too scared of damaging the pipes with a hacksaw, so wore them down with a file until I could rip them open and off with an old jeweller's screwdriver icon_smile.gif
Back to top
 Alert Moderators
scatmanjohn
from Brazil
Thanked: 108 times
PostPosted: Tue Nov 28, 2006 8:27 pm Reply with quote
i use these
Back to top
 Alert Moderators
Blasphemous
from United Kingdom
Thanked: 15 times
PostPosted: Tue Nov 28, 2006 8:30 pm Reply with quote
Crikey!!! The award for perseverance goes to.... YOU!
Back to top
 Alert Moderators
micktheframer
from United Kingdom
PostPosted: Tue Nov 28, 2006 8:36 pm Reply with quote
I'm with scatmanjohn on this one....
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 319 times
PostPosted: Tue Nov 28, 2006 9:26 pm Reply with quote
Never used or saw one, to be honest never saw the need... Is it so much better and quicker than the 30 seconds it takes to cut with a junior hacksaw and an remove with an old electricians screwdriver. Or just wallop the nut an olive off with pair of grips.
Back to top
 Alert Moderators
dan the man
from United Kingdom
PostPosted: Tue Nov 28, 2006 9:33 pm Reply with quote
scatmanjohn wrote:
i use these
yup i use these in 15 and 22.
otherwise a hacksaw is easy enough imo if u get technique right
Back to top
 Alert Moderators
pigeon1974
from United Kingdom
PostPosted: Tue Nov 28, 2006 10:26 pm Reply with quote
I use both and the one scatman recommends is the best. And it helps strengthen the wrists.
There is a technique though -be careful and slow (that's what she said) or you can nip the copper pipe as well.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 4
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Olive Pulling Tool 15 1840 Sat Feb 21, 2009 8:06 pm
Removing an Olive from 15mm Chrome Plated Copper Pipe 2 920 Sat Aug 25, 2007 4:57 pm
removing olive issue 4 440 Mon May 17, 2010 8:13 am
Best way to remove an olive ? 15 900 Wed Jan 13, 2010 11:00 pm
Changing a TRV. Olive question 8 440 Fri May 01, 2009 6:39 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
