Got an old boiler, CH works, DHW does not work.
Suspect it could be divertor valve- I have manual but no mention of this - I think it called the 'water section'. So probably new valve or diaphragm
Also possible problem with flow switch have adjusted actuator for the two microswitches -this gives me Immediate HW, but then they go out of adjustment shaft moves but not enough. So suspect that I need to change flow switch stuffing box too.
Is this all worth doing ?
Three heating engineer so far and no-one even wants to hear whats wrong just want to sell me a new boiler for £2.5K (more efficient, cheap to run blah, blah-Even if I use half the gas payback is ten years)
I've got to take up and trash my brand new wooden floor cause old boiler runs on 15mm not 22m gas pipe if I fit new boiler !!
Anyone who knows how to mend an old Vaillant combi' in Brighton
