Fitting Radiator
15 Jul 2006
Suffolk
I have purchase a new rad, same size as the old one.
Fitted a TRV.
The pipework comes out of the floor, which is a ground floor and have no lateral movement.
The radiator fitted with the couplings is to wide for the existing pipework by about 1/2". I am concerned if I pull the pipe to much I will end up bending it.
What is the best solution, Is it ok to use a flexible.......
No. You'll have to put a Z in at least one of the pipes.
put a bending spring down the pipe and you may get a bend if there`s enough sticking out the floor to manipulate
