ChrisR said:Hugo the fault description would be unusual. All I can think he means is that the heat exchanger is leaking water, which is then evaporating until it condenses in the flue and then leaks out. Does that sound like what he meant?
Does the pressure gauge drop quickly? It would.
Where exactly is the leak?
Hi Chris, I dont know where the actual leak is, all I know is that water is coming out of the flue pipe on the outside of the wall, yes the pressure drops very quickly, the plumber didnt mention anything about evaporation.
Cheers
