whirlpool dishwasher error code
15 Nov 2006
Cambridgeshire
I got Whirlpool ADP 4501/5 dishwasher its been working fine. Now its not working. it has a flashing green light( 7 times), i believe this is and error code!!! I think thats its something to do with the water. maybe!!!!
Ive disconnected and checked water supply and still flashing 7 time.
ive now sorted the flashing 7 time, ive got it flashing 6 times, any idea what that could be and how to fix it
Is it taking water in?
6 flashes is a problem with water intake. Normally it changes from 6 to 7.
check for kinked fill hose.
is the water pressure good enough?
Failing that, left hand panel off, unplug the flowmeter, plug it back on and try again.
hey thanks for that.
its started out as a 7 code then i took the bottom panel off and disconnected the reconected all the plugs.
Now its flashing 6.
Ive check all the pipes , and they are ok and the presure seems ok too. Not sure if its allowing water in or not!! Ive looked inside and the filter is clean and looked in the bowl and that looks ok, i couldnt get the plastic black gard off to see inside. :cry:
thanks sleepyhead. Took side panel off, disconnected then reconnected the flow meter. Seems to be working fine now. Top Job
Thanks sleephead. I have an ADG 7556 M and this worked !!!!
