Wall papering an Arch.
20 Oct 2006
West Midlands
Hi, I have just had an extension built on to my lounge. What was the French doors is now an Arch into the new room. It is a standard arch. A square opening with the corners rounded.
How do I paper this arch?
Regards,
Gary.
Ooooo...tricky mate..firstly, if the paper isnt going in both rooms you need to decide what room you want to see it from.
As foractually doing it, theres two ways I use depending on the paper and the light source.
One way is to paper the inner part of the arch from the top of it to the bottom using two pieces of paper overlap them at the top by about 2 inches and cut through the two pieces..take away the two bits of waste and you should have a perfect joint.
The two pieces should overlap the outsdie edge of the arch on both sides by about 1/4 inch.
Next, make a snip in the paper every inch all the way round and stick the paper to the wall...then you can paper the face of the wall.again leaving about an inch hanging over the edge, then take a very sharp trimming knife and cut the access off
The other method I use is almost the same but paper the main walls first snip the edges, fold it around and then place two strips over the inner part of the arch
Dont forget to wipe the paste off as you go..
If the paper is very thick then youl have to cut bot edges off at the external corner, if you dont they will show under the paper
Sorry if it sounds complicated...its harder to explain than actually do
Oh and dont go for a complicated pattern you will lose it all over the place on an arch
glad you got the job steve :LOL:
I try to con the customer into having the reveal painted... :evil:
:LOL:
Not an easy one..I waited for someone else to reply for a while lol...nice to see you back btw
:LOL:
Ta steve...likewise.
I've been working on an empty house and quite knackered.. Gettin old :eek:
Hi Zampa - do you suggest joining two strips on the inner arch because it saves wasting an entire 15 feet length, or does it actually help hang the paper in another way?
Cheers
Oz
Ignore previous post - just realised pattern would be upside down on one side of arch. Sorry, just having a doh! moment.
Oz
