| Author |
Message |
ptarling
Joined: 07 Mar 2006 Posts: 12 Location: Essex, United Kingdom
Posted: Thu Sep 28, 2006 9:55 am |
Hello,
If anyone can give me some advice - would appreciate it...
Thinking of buying an olive removing tool. As far as I can see there is a cheaper model that will remove both 15/22mm olives (the tool screws on to the existing compression locking nut and you pull the olive off) or there is a more expensive tool that splits the olive (but 2 seperate tools required to do both 15 & 22mm).
Will the cheaper one suffice or are they unreliable..???
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
JPC
Joined: 10 Aug 2004 Posts: 1568 Location: Leicester, United Kingdom Thanked: 19 times
Posted: Thu Sep 28, 2006 4:12 pm |
i bought a 15mm mor expensive type.
it lasted about a month. the cutting teeth are now blunt and it compresses the olive (and pipe) and in so doing causes more work !
i now have gone back to me hack saw |
| Back to top |
ChrisR
Joined: 24 Jul 2003 Posts: 23083 Location: London, United Kingdom Thanked: 936 times
Posted: Fri Sep 29, 2006 12:51 am |
I've got them (all!).
The screwy one which does both sizes (unless the threads's the older finer prestex type) is the better bet.
Either that or cut yourself a set of very short lengths of copper pipe, and put them in a compression fitting, starting with the shortest, and do the nut up. As you do so it'll slide the olive along the pipe. When tight, undo the fitting and put a longer bit of pipe in, and repeat. See? |
| Back to top |
croydoncorgi
Joined: 06 Jun 2004 Posts: 4024 Location: London, United Kingdom Thanked: 331 times
Posted: Fri Sep 29, 2006 7:13 am |
The splitting-type tool does for me, for 15mm. Larger sizes = less frequently needed and easier to work on = carry on using hacksaw.
The other problem is the quality of the plumbing BEFORE you came on the scene! If a compression joint has been over-tightened so that the olive has dug in and 'necked' the tube, there's no point removing it in most cases! You won't get a leaktight joint on the tube a second time anyway. |
| Back to top |
ChrisR
Posted: Fri Sep 29, 2006 8:44 am |
The plug centre of the screw-on type, goes some way to reshaping the pipe.
SOmeone ought to make a tap-in bar of the right size to do the job. 13.6mm! |
| Back to top |
ptarling
Posted: Mon Oct 02, 2006 9:39 am |
| ChrisR wrote: | I've got them (all!).
This sounds like a good plan!!!! Thanks for advice |
| Back to top |
ptarling
Posted: Mon Oct 02, 2006 9:42 am |
| JPC wrote: | i bought a 15mm mor expensive type.
Thanks for advice!! |
| Back to top |
ben28
Joined: 02 Oct 2006 Posts: 5 Location: Yorkshire, United Kingdom
Posted: Tue Oct 03, 2006 4:22 pm |
I have monument 15mm/22mm removal tool, it is very usefull and avoids the problem of cutting the pipe and the olive when using a hacksaw. Occasionaly the effort required to turn the handle can be difficult in tight spaces. On the whole its a usefull bit of kit though. |
| Back to top |
nigelad
Joined: 08 Oct 2005 Posts: 60 Location: London, United Kingdom
Posted: Tue Nov 28, 2006 8:23 pm |
Didn't know you get tools to deal with olives until I saw this thread!
I replaced 9 rad valves with TRVs recently, and removing the old olives was the hardest part of the job!
I was too scared of damaging the pipes with a hacksaw, so wore them down with a file until I could rip them open and off with an old jeweller's screwdriver  |
| Back to top |
scatmanjohn
Joined: 02 Nov 2005 Posts: 3081 Location: Brazil Thanked: 100 times
| Back to top |
Blasphemous
Joined: 02 Oct 2006 Posts: 6645 Location: United Kingdom Thanked: 15 times
Posted: Tue Nov 28, 2006 8:30 pm |
| nigelad wrote: | Didn't know you get tools to deal with olives until I saw this thread!
Crikey!!! The award for perseverance goes to.... YOU! |
| Back to top |
micktheframer
Joined: 20 Nov 2006 Posts: 34 Location: Birmingham, United Kingdom
Posted: Tue Nov 28, 2006 8:36 pm |
I'm with scatmanjohn on this one.... |
| Back to top |
namsag
Joined: 12 May 2004 Posts: 9913 Location: United Kingdom Thanked: 319 times
Posted: Tue Nov 28, 2006 9:26 pm |
Never used or saw one, to be honest never saw the need... Is it so much better and quicker than the 30 seconds it takes to cut with a junior hacksaw and an remove with an old electricians screwdriver. Or just wallop the nut an olive off with pair of grips. |
| Back to top |
dan the man
Joined: 12 Aug 2006 Posts: 173 Location: United Kingdom
Posted: Tue Nov 28, 2006 9:33 pm |
| scatmanjohn wrote: |
i use these |
yup i use these in 15 and 22.
otherwise a hacksaw is easy enough imo if u get technique right |
| Back to top |
pigeon1974
Joined: 11 Nov 2006 Posts: 10 Location: Anglesey, United Kingdom
Posted: Tue Nov 28, 2006 10:26 pm |
I use both and the one scatman recommends is the best. And it helps strengthen the wrists.
There is a technique though -be careful and slow (that's what she said) or you can nip the copper pipe as well. |
| Back to top |
